Can I drive a 911 for 7 years for $44K?
I am sorry that this is a lame question, but I have been teaching for 18 years and still earn in the 40's. I have to be very careful not to get in over my head. That said, I already have a 04 accord (winter beater), 93 civic (200hp, summer car), 94 NSX, and 91 miata (turbo, etc..). The civic is great fun (even better at the track) but a little embarrassing for a 42 year old. So I want a four seater that is gorgeous and phenomenal to drive. Is it even possible to buy and maintain a 996 911 for seven years (figure about 6K miles a year) for a total of $44K? Not including insurance, of course. I can do basic repairs myself and have access to lifts and capable buddies for engine and transaxle removal. What do you think?
#1. There are no "basic" repairs on a Porsche.
#2. A replacement engine is $20,000.
#3. Porsche dealers charge $100+ for labor.
#4. Your joking, right?
I suppose you could, if you give your kids away, dont, eat, and live in a tent. If your a good DIY'er maybe you could. Unfortunately these cars are VERY expensive to own. Buying one is the easy part.
Im just kidding about #4 but not #1 thru #3.
I too am a public servant so I get where your coming from.
It sounds like you are capable and have access to equipment that may be needed, so I'd say YES, absolutely. Never mind what Krazy says, he wrenches on his own car (saves money, very good) but seems to think that the dealer is the only source for any part (not true at all). Many parts are available for significantly less than at the dealer, especially common replacement parts, with equal quality.
Tires will very possibly be your biggest expense. Don't plan on needing to buy a replacement engine, it is extremely unlikely that it would need one.
Basic maintenance is no different than any other car, an oil change is easier than on your Miata.
If it needs something more complex, the beauty of a 996 is that there is most likely a video on how to do it, and for sure help on this forum and others like it.
The important part is to look at what's out there and choose carefully. Do a lot of reading up front, ask a lot of questions, and don't be scared off. Quite a few people on here use these as daily drivers. And even more people here do their own work.
I don't think that on average they are (or have to be) very expensive to own compared to what you get back....Sure, more than a Civic, but a lot less than a lot of other machinery. I will not perpetuate the myth that you have to be rich to own one, absolutely not the case, especially if you are somewhat handy or perhaps more importantly, have access to others who can help.
You only go around once, gotta do what you want as long as you prepare yourself properly.
02+ 911 will run you about 25K and if you get clutch/intermediate shaft replaced for ~$2K tops you're in good shape (~$1K in parts). Access to lift is totally awesome, you'll be able to do more than than 90% of people on this forum.
Pics of the NSX?
Pics of the NSX?
Go for it and welcomemto the 996 Family. I recently picked up an 04 996. I splurged for a newer one but started off looking for a 99-01. I preferred the engine upgrade on the newer model. You only live once.
I had a '99 Cabriolet for 7 years. I bought it near mint for $47K in '03, sold it near mint in '10 for $30K. I put 30K miles on it, spent about $1K parts (clutch, pp, bearing, coolant tank, MAF sensor, back up light switch), $2k labor for goodwilled motor install, + gas, oil, tires.
I've had my Turbo nearly 2 years and the only repair has been a clutch accumulator @ $130, installed it myself. Three oil changes, each costs $50 for oil $6 for filter.
I bought an '02 at a steal - and car is probably still worth more than I paid for it (or at least the same) - so no depreciation. Service costs have been ok for performance car so far (in 2years <$200 for oil (DIY), Plugs/Oil Pressure Sender/transmission fluid, window regulator $1K) Tires+Alignment $1K, Front Brakes $350 DIY. I am budgeting for new clutch, AOS, Water Pump, IMS in near future (say ~$4K) - but if you divide those costs over 4 years - it works out to <$2K/yr - not bad for an exotic. (but a lot more than your civic, miata etc. probably). The risk is a much more expensive engine problem.
But then again, if you purchased a new M3 (for example) it would cost you a lot more - just on depreciation.
Same person, same tune, every thread. KK has probably 'unsold' more 996's than just about anybody.
2) Who said anything about needing a new engine? Even if that's the case, you're quoting dealer pricing; my plan is to pull one from a yard or have the current rebuilt for ~$15k.
3) And independents charge half that...and if you do it yourself, it costs nothing.
$44k is plenty for both the car and an emergency fund to tackle even the worst scenarios (at shop parts and labor rates!).
Easy enough to find a good 55,000 mile 2002+ 996 for $25K-$30K. That still leaves a very generous part of your budget for scheduled service and the typical replacement items. Even plenty for a clutch when needed and throwing in an IMSB at the same time. Now if you roll it into the dealer every time you have the smallest issue, it can get expensive quickly, but that is true for *any* late model car out of warranty.
Not sure about the four seater part... Even if your kids are small enough to fit in the back of a 996 now, the probably won't be in seven years!
In short, yes, you can. As others have mentioned, you can get a good C2 for 25-30k, and that leaves quite a bit for maintenance for the next 7 years. Especially if you have access to a lift, and some capable friends. Krazy is just that, so even though he chimed in first, I would factor in his information last.
Cheers,
DS
Cheers,
DS
