IMS Class Action August 3rd Update. New Claim form Claims Posted
#241
Rat Balls
I have been wondering how many engine failures are misdiagnosed as IMS related? With the requirement by PCNA that the owner prove the failure was IMS related, the silver lining could be the IMS failure rate could go down.
On the contrary, to take advantage of the settlement it may benefit the Dealer/Servicer to state an IMS failure when the cause of the engine failure was related to something else. This could result in the number of IMS failures to be over reported.
#242
I'm wondering what percentage has actually been truly IMS related damage since there have been so many that just assumed and chalked it up to IMS. We all know there are other modes of failure as well, including that of the owner to properly maintain or use(abuse) the car.
#243
FWIW,
I did find the old blurb again about distinguishing single row from double row cited by Softronic as a source but IIRC, the same range was also part of the LN website at one point. Later it was pointed out that this wasn't entirely accurate and that you should do a visual inspection of the flange to determine the single vs. double. Interesting nonetheless...
According to PET, here are the engine numbers for single or double row bearings* up until late 2005 then 2006 and later engines which received a larger, non-servicable single row bearing. *Courtesy of Scott Slauson http://www.softronic.us.
Boxster: Double Row: up to 651 12851 (M96.22) up to 671 11237 (M96.21)
Single Row: from 651 12852 (M96.22) from 671 11238 (M96.21)
996: Double Row: up to 661 14164
Single Row: from 661 14165
#245
Former Vendor
FWIW,
#246
Also does anyone have the full PET docs to reference what Softronics was talking about?
#247
Former Vendor
The record keeping was horrible, today if a car is a 2000 or 2005 it has to see a visual inspection to know what bearing is installed.
#248
The LN directive was pulled after people started bitching about its accuracy. The directive was created from the factory releases on the topic.
I was just trying to see if those number ranges correlated in anyway to the number ranges listed in this lawsuit, but the numbers seem confusing with the various ranges for me to make any sense of it.
#249
Thanks as I've stated in my previous post, I think we are in agreement that a visual inspection is needed instead of speculation.
#252
Still plays with cars.
Update and a reminder - nothing can be done until the court accepts the settlement. That is supposed to happen this month. Please don't call the lawyers until I confirm that the court has accepted the deal.
Regards,
Regards,
#253
You guys do realize that for Porsche to actually admit there is a problem with their design and agree to civil penalties or remedies, that the problem is far, far worse than anyone can imagine? If civil litigation were allowed to proceed through a court, discovery including interrogatories would probably do great damage to the brands reputation.
Can you imagine what kind of emails, memos, notes, etc. have been sent back and forth between employees, techs, and engineers about this problem? Then throw depositions where cross examination is allowed in the mix and you just destroyed a company.
Porsche has an A+++ legal team to fight any civil onslaught so you can be assured the problem is many times worse than you may think or they would have remained silent.
And if there was any chance to insinuate a hazard to the consumer or public, its over.
#254
#255
