Where can I buy connectors for microswitch?
I finally got around to doing the window regulator in my passenger door. When I got the door panel off it became very evident that someone had been there before. The wires to the microswitch on the interior door handle were pretty much just pushed into the switch then taped there, and the two for the led in the handle were boogered up also. I called my local dealer thinking "how much could these possible cost?" and they're not available at any cost. These pieces are far to small to work with and I would much rather a connector. Any have any ideas where to find these, or an alternative?
in all honesty your best bet is to soulder wire to the micro switch and then add your stadard connectors to the wire leads
