when did you change your clutch?
35k, 69k, 96k, but since then, this clutch is still going (which I find strange).
i haven't changed my driving habit, but the car sees a lot of track time. If you get 45k, you're doing good for this car.
I did mine at around 64k and the only reason I did it was because the throw out bearing went, When I pulled the clutch it still had about 40-50% on it compared to the new one.
Around 65K miles, also did the IMS fix, RMS....the normal stuff.
To me, that was normal maintenance....the trans needing a rebuild for 2nd gear and diff was more of a pain in the pocket. Make sure you do not have a 2nd gear pop out issue before you get the clutch replaced.
Oh yea....a Porsche mechanic would tell you to replace everything at the same time...seats and all...LOL.
