double beep and doors wont lock
Recently I noticed that my remote required two presses to lock the doors.
Then last Friday the lock failed altogether and I am getting double beeps signifying that something has failed in the locking mechanism.
This is a 2001 C4 Cab with around 60k on the odometer.
I had already been experiencing the failure of the window to drop on drivers side during closing(Have not repaired this yet) and recently I replaced the switch mounted on the ignition switch because the key was getting hard to remove and I was getting intermittent lights left on indicators which required cycling the key.
I can not lock it with the inside switch and I also can not lock it manually with the key. When I turn the key clockwise I feel resistance and the lock pushes the key back counter clockwise.
Is there anyway to narrow down what module has failed other than getting a scan?
Thanks in Advance.
Thanks in Advance.
Rocky Mountain High
The double beep means that something is open. The usual candidates are the armrest in the center console and an aftermarket radio installation. Do you have an aftermarket head unit? In your case, the door peoblems that you are experiencing my be part of the issue.
I have a 2002 Targa with 80k miles and had to replace both door latches and window regulators when I bought the car a few months ago. Was experiencing similar issues, lights staying on, windows now dropping, etc.
Battery is maintaining 14 volts on gauge if I can believe it.
Dennis C - I think single beep signifies something is open. Double beep means something is broke or wire shorted to ground or open or ...............
Checked all fuses in the alarm lock module on the fuse panel - three of them.
Did not check fuse on computer under seat - can you get to it without removing the seat?
Checked wires under seat because I had issues in the past where the wire bundle got snagged under the rail and scraped insulation off of one wire.
Did not take it to anyone for a scan - which is less expensive? Buying a Duremetric tool or getting a scan done?
Read owners manual to see how to manually lock the car. Did not see which way you rotate the key to lock the doors as I always used the remote since I bought the car 2 years ago. By trial and error it appears I rotate the key clockwise and than back and that locks the doors. The first time I tried it I was able to only lock the drivers door. The second time both doors locked and the fob locked and unlocked the doors with no beeps.
I got to work locked the doors with the key and recalled I needed something out of the car. Tried the fob and got the beep beep again. Manually unlocked the car and tried the FOB to lock it again and no dice so locked it manually.
I am hoping I have a lazy lock mechanism and I hope it is the drivers side as I have had problems with the window dropping - and yes I know it could also be the window cable is stretched.
Anyway I cant get the trim piece off the stationary pull handle on the drivers door. I tried buying a plastic putty knife/spatula at a couple of auto parts stores similar to the plastic tool I see in an online video for removing the trim but no one sells one.
I also have read that if you are not careful removing it you can break one of the snaps. And BTW - it is leather interior which adds to the challenge.
A DOUBLE beep means there is an alarm fault.
A SINGLE beep means one (or more) zones are open and unable to arm.
You have an alarm fault and will need the alarm fault code(s) to diagnose further.
What Loren says.
I can add when my 02 Boxster did the same thing: Inexplicable double beeps when locking the car, passenger side window not dropping when I opened the door or worse dropping then once open going up again, and the door locks coming on on their own accord while driving, the problem proved to be a bad passenger door lock assembly. This is the biggie in terms of size, complexity and parts cost. Labor to replace is an hour or two I can't remember now.
The tech hooked up the Porsche diagnostics computer and did some checking to see if it was a less expensive part but the error codes from the car's security controller pointed right at the door lock assembly.
Hi
I have exactly the same symptoms (double beep, having to click the remote twice for a lock and driver's side window does not retracted when closing).
The Durametric gives the following codes. Does anyone have any ideas what the actual offending part/s may be:
60 - Central locking limit position Lock not reached
61 - Central locking limit position Unlock not reached
1 - Door(s) secured and terminal 15 on
44 - Alarm actuation by driver's door
47 - Control locking synchronization
Anthony
2001 C2 Coupe Tip. 43,000 kms.
Anthony
Sarc1218 (09-22-2020)
Hi
Anthony
Anthony
- Short circuit to ground/open circuit in wiring between the alarm system control module, central locking switch or door locks
- Driver's/passenger's door lock faulty
My bets would be on the faulty lock/microswitch on the driver door.
New to me 996 won’t lock
I know this is an old thread.. but I’m Searching around online as I just bought my first 996. Previous owner told me battery recently died and door locks won’t work because low battery voltage. Voltage looks fine on the dash. Thinking it might be faulty actuator like mentioned above. Any suggestions appreciated!
Otherwise it is an expensive guessing game. Mine ended up being a cold solder joint in the passenger door latch assembly.
Never would have isolated it to that switch without a tool that showed me that the switch showed open even with the door closed.
To really diagnose a locking problem you need either a Diametric, or a code reader that can see microswitch positions ( I use a foxwell NT130)
I had an issue where the glovebox microswitch failed, leaving the light on. Would slowly drain battery and also do the double honk thing. Scanner made it quite and easy.
Icelia (07-14-2022)
Since replacing bulbs in overhead of my ‘00 C2, I’m getting the double beep on unlock (with key, fob doesn’t work). Checked arm rest, front and rear lids, and sunroof. No fault codes showed up using a Durametric. I may have damaged the sensor in the overhead unit, but wouldn’t that give a fault in the alarm section?
