Is my '99 996 running hot?
My 996 is running with the needle covering the right hand side of the "0" in 180. I seem to remember it covering the left hand side of the "0". Weather temp does not seem to affect it. I had the radiators separated and blown out and a new cap on the reservoir. I also had the rubber baffle under the spoiler replaced as it was torn. I wanted the air channeled as was designed. My mechanic says '99's run a little warm. What do you guys think? Should I have them look into a thermostat and/or water pump? Just had the 90k mile service and there were no red flags. Thanks.
mine is the same and has been as long as i can remember.
A little to the right of center on the "0" on a warm day in slow traffic or during spirited driving and centered on the "0" when on the freeway.
I proactively changed the water pump and thermostat just before my recent road trip and it had no effect on the temp. reading so i am of the feeling this is normal running.
Pete
Pete
my 99 was also running that hot, checked the fans, one wasn't working.was just a fuse. Now runs a little cooler but still warms up in traffic but not as bad.
Sounds like you have recently flushed your coolant as my indy says old coolant can cause problems.
Anyhow, you need to know the coolant temp. The gage isn't real accurate.
With a '99 you can, I believe, using the AC control buttons enable some kind of diagnostics mode that you can then using the temp (or fan speed) control buttons cycle through 20 or so diagnostics data items. One of particular interest is the coolant temp.
I do not have the instructions to call up this mode nor how to pull up the coolant temperature reading but these exist at various places, probably here or on RennTech.
The car has enough miles that a good inspection of the water pump wouldn't be a bad idea to see if it shows signs of leaking. It is almost certainly not responsible for any possible overheating as this requires the pump either not turn or have enough wobble to have the impeller blades contact the engine casting and break off.
You can check for any water pump play and check the belt for sharp edges. These can arise from worn bearings which allows the belt to track wrong and rub a pulley.
If you are really paranoid start the cold engine and carefully (!) check/feel the coolant hoses to/from the water pump to feel them get warm as the T-stat opens. If they do not get warm the T-stat could be failing to open fully.
Now it just so happens this is I think and so does the tech what happened to my Turbo which uncharacteristically had its temp gage needle venture into a region -- about half way between the 180 hash mark and the hash mark halfway between 180 and 250 -- in which it has never ventured before the other day in 100F ambient temperature. Also, I smelt the strong odor of anti-freeze.
Further inspection by the tech and I found no signs of a coolant leak (the level was just down to the min line but no lower) but the driver's side radiator fan is not working at 100%. There are no fan stage error codes from the DME but a simple feel by the hand detects very little exhaust air from the radiator exhaust opening compared to the other side. Now the car has had a radiator fan fail before -- the passenger side -- but even with one fan the engine temp gage hardly budged (not even a needle's width) above where it normally hangs out. The A/C worked just fine too. Anyhow I have a new T-stat and drivers side fan on order. Should be here Monday and both in by Monday COB.
Back to your car. Absent any signs of a coolant leak and if you drive the car and the coolant temperature remains reasonable I believe the odds of there being anything wrong with your car's cooling system is nil.
That is where mine runs when in stop and go traffic. Runs between the 8 and the 0 when I am cruising.
Isn't it nice when you discover you probably don't have a problem!!!!
Happy motoring,
Ray
Happy motoring,
Ray
Soaringman, That's where I am on temp. Is that after you replaced the fuse that got the fan working? If not did it get cooler after? Thanks
I'm by no means a Porsche expert or even close but i don't like my engine running hot and am happy when the needle is between the 8 and 0.
my manual says the needle should be straight up and that's where I like it.
I do plan on cleaning my radiators in the near future and this may well help.
Yes I think you are running warm. Mine ran at this temp and it was due to one side rad fan not coming on low speed. Now that i have that fixed it runs with the needle at 12:00 Pos. Where it had for years. You have to ask yourself if its really running hot. Only you know your car and whats normal.
Mine runs just like that on the gauge. Dealer says it is normal. Mine never gets over the end of the zero though on the gauge. Where this picture shows the needle is the max mine gets in 95 degree weather in traffic.
