996 Forum 1999-2005
PCM cannot Enter Navi Code
Old 09-22-2013, 03:36 PM
paulv996
5th Gear
paulv996's Avatar
Default PCM cannot Enter Navi Code
I just replaced a battery and now i cannot enter my navi code. This prevents me from using the radio. I see options but no adjustments. 02 c2 navi pcm1.0. Nav works frin all other functions appear right. Any thoughts.
I have disconnected and reconnected the battery i can enter the pcm code just cant scroll to navi.
Old 09-23-2013, 11:17 AM
Loren
Loren's Avatar
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM?s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC.
Old 09-23-2013, 01:36 PM
paulv996
5th Gear
paulv996's Avatar
Default PCM Codes
Yeh - thanks for the response! I have both codes! I just cannot scroll to enter the second. The screen shows the line item but it is not accessable for code entry.
Quick Reply: PCM cannot Enter Navi Code
