996 Forum 1999-2005
Change targa roof motors DIY?
Old 09-30-2013, 12:25 PM
Scuddriver
Scuddriver's Avatar
Default Change targa roof motors DIY?
Hi
My 996 targa has been in for repair of the targa roof and I will pick it up tomorrow. The Porsche center has changed the complete mechanism incl. wires and guides so the operation and alignment should be as good as new :-)
The motors that operates the wires are however a bit rusty and make a slight noise... Porsche Center decided not to change them at this point as their operation is ok.
What I am trying to find out now is how hard it is to change these motors if / when i find a better set on ebay or else where....
I know their location, and from what it looks they should be easy to change. I know their sync is critical and I am wondering if you can change them without reprogramming them if changed one at a time as long as the sync of the wires are not changed.
Old 10-01-2013, 11:07 AM
Loren
Loren's Avatar
It takes up 16 pages of the service manual (covers both motors).
Doesn't look to hard and you will need to remove and re-install the microswitches.
Old 10-01-2013, 02:12 PM
Scuddriver
Scuddriver's Avatar
Does it look like it can be done without the use of a Porsche computer? Any way you could share the manual info?
Old 10-01-2013, 03:50 PM
5CHN3LL
5CHN3LL's Avatar
A little lubrication can make an old electric motor VERY happy...
Old 10-01-2013, 04:29 PM
Scuddriver
Scuddriver's Avatar
In this case the cogs on the motors are slightly damaged so I really need to change the motors.
Old 11-22-2013, 10:45 AM
Scuddriver
Scuddriver's Avatar
I finally found a new set of motors at the right price from a company in Albuquerque NM. They are on their way to Sweden right now. If no one can provide more detailed info about how to change them change I will probably go wit Porsche Center Gothenburg...
Old 06-05-2015, 02:58 PM
911 Oli
3rd Gear
911 Oli's Avatar
Default 2007 997 Targa 4
I have a 07 Targa 4 , and since a short while the Roof wont close anymore....
gets kinda stuck half way or simply does not close at all.
Sometimes pushing it all the way up to close helps but not all the time.
I took it to the Shop and they told me the "plastic pins" (Guardrails) are worn out (broken?) and this has to be a complete redo .
Porsche sells a repair set (?) for round bout $1000 !?
Labour of course would be way more as difficult to get in or out etc.
Anybody any experience similar / same issue?
Thanks a lot !
Quick Reply: Change targa roof motors DIY?
