ROW M030 vs Expensive Coilovers??
So winter is approaching and thoughts start on what work to do on my 45k mile 40th. Last year I did all the brakes and this year I am thinking of suspension as well as front bearings as one of them is starting to show some play.
I use the car as a DD here in MN (read crappy roads), with 2-3 track DE’s a year. My primary goal is reducing some of the 4x4 look, yet not sacrificing the ride. I was thinking about going for a new set of ROW M030 springs, to replace my US 030 that came standard. At $1200 from Sunset they seem a great deal vs $3,000 for full on coil overs.
Any suggestions from many of you that I am sure have modded your suspension, is the extra money for coilovers really 2x better that a new set of M030?
One advantage with the coilovers is you can adjust them to soft when DD and then to almost full hard at the the track for better handling. The coilovers can lower your car but you have some control over just how much it lowers it.
I replied to your PM- I have a blast at DE's on the stock m030 springs and the konis, but the 4x4 look is still there. ROW m030 is a great ride height but there is something to be said for coilover adjustability- you can always just change the ride height and damping if you don't like it. Not so with ROW m030 setup.
As someone mentioned, the ROW kit seems to be a mixed bag at best in terms of the ride height. Some have barely noticed a difference.
I'm not sure you wanna take that chance if your primary focus is on ride height.
Non CO option would be H&R springs paired either with Bilstein Sports or Koni FSD's which would offer a more compliant ride.
It's really a shame the x74 option is NLA.
For clarification, I have koni sports, which are rebound-adjustable via a **** on the top of the damper. The Koni FSDs are supposed to be self-adjusting depending on your driving conditions but I have not heard any first-hand reports about how well they work...
I have a 40th anniversary and switched to M030 RoW in April this year and I'm very pleased. It definitely dropped the ride height but its very compliant. I could feel the change from 9 yr old suspension and for the cost from Suncoast it was a bargain
Sorry, I wasnt clear, lowering isn't my priority, just a nice visual byproduct of changing out the suspension.
I just think my suspension isn't at it's best at 10 years old and 45k, it's by no means bad, just not as good as the day it rolled out of the factory.
So I would like to refresh it, if possible improve it's ride quality, but not sacrifice its track abilities for the few times I track it.
I would prefer to stay OEM, I think Porsche nows more about what works over a broad spectrum of driving than most aftermarket. And don't think I can justify $3-4k for coil overs vs $1200 for M030 ROW.
I am just unsure, how much improvement it will be over my std US M030 setup.
I'm also considering ROW M030, I'm at 80k on stock suspension. My car seemed to under steer at the track, hoping this would clean that up. Slightly lower is a nice by product, and I don't want something too harsh for a DD.
Local Indy quoted me $700 for installation and alignment, seems high to me. Is that reasonable? I've already dumped a bunch of money into the car since buying in May (made the mistake of adding it all up.) Having trouble justifying it to myself as my suspension is still adequate...
Installation isn't bad if you have access to a decent spring compressor. Of course if you aren't reusing springs you might not need the spring compressor. Access to a lift is also a huge help too, even if it is just a small scissor lift. I did mine in an afternoon. $700 does seem steep. $4-500 would be reasonable I guess @ $100 an hour.
