ECU flash RoW software '99-'01
Anyone who has flashed their US '99-'01 3.4 with RoW software?
Any issues? The RoW software should not trigger the CEL as much as the RoW software.
Do you have any fault codes after the flash?
Once you have your cars programming codes from a dealer it can be done in the car with PST2 or PWIS
EU software is designed for 98 octane.
I have the EU3 software (European Union) for my race car that only runs 100oct race gas.
I don't believe there is a "ROW" version.
http://books.google.com/books?id=Raa...%20eu3&f=false
If this is for a street car and you will not be running 100 oct gas. I would stick to the stock mapping.
For the '99-'01 3.4 using DME 5.2.2 it seems there is a RoW version, or am I mistaken?
If anyone is using the RoW or EU software in their US Porsches, have you come across any problems? Any fault codes?
http://books.google.se/books?id=Raan...%20RoW&f=false
I'm highly interested in this, but for a 996TT. The ROW cars (afaik) do not have smog pumps or secondary o2 sensors.
And yes, there is a program that does not use the after cat sensors.
Note that some changes may require different cats to prevent damage (and emissions).
In the US these are only legal for racing purposes -- not street driving.
Captain Obvious
Super User
Super User
Europen octane rating and North American octane ratings are not the same thing. The EU 98 is about the same and the 94 we have here.
Also, why would the secondary O2 sensor fail faster with the catalytic removed?
Why doesn't someone just make an relay or something that manipulates the ECU to think that the smog pump is working, and then get a set of o2 spacers for the secondary sensors, or maybe a set of manipulators? Those are readily available.
If I find something out, I'll post up. I have a few 996's that need this done. Plus there are (from what I remember when doing a vacuum system upgrade) around 3 vacuum lines going to the smog pump and bits. 3 more places for a vacuum leak we don't need.
