OBD code P0348
OBD code P0348
OBD code P0348 the info from my basic reader displays "camshaft position sensor A - Bank 2 Circuit high input"
Is a 2003 C4S 75k miles. I've a Durametric on order. Any thoughts ?
A poster on PP, yelcab1, said this
Codes starting with 0 are all generic codes required by law. This code says your cam position sensor impedance shows high values. It means your sensor is bad, or has a broken wire in the connector. The fix is to replace it. Clear the code, and drive.
Seems to match what I've been reading elsewhere too.
