996 Forum 1999-2005
Oem 5mm spacers or aftermarket 7mm?
Old 11-12-2013, 02:42 AM
pfbz
pfbz's Avatar
Received 2,727 Likes on 1,465 Posts
Just so we have the terminology straight, when referring to spacers, my understanding is that:
  • Hub-centric means that the spacer itself is designed to fit perfectly on the factory hub lip, as opposed to a spacer that just centers on the lug bolts.
  • Wheel-centric means that the spacer has an additional protrusion lip that the wheels can sit on. I've never seen this in 5mm spacers, as the factory hub lip still protrudes past a 5mm spacer. I think most 7mm spacers are also not wheel-centric.
Old 11-12-2013, 02:50 AM
Philip P
Philip P's Avatar
I used http://www.motorsporthardware.com/porsche/ and was very happy with them. I have had no problems with vibration or shaking of any kind. Currently running the 7mm with extended bolts as well.
From my understanding they make a lot of the H&R stuff.
No affiliation
Old 11-12-2013, 06:21 AM
chsu74
chsu74's Avatar
FVD 7mm spacers are wheel centric. Call them.
Old 11-12-2013, 10:25 AM
roadsession
roadsession's Avatar
Hi guys - I know I know - don't always listen to the dealer, but I was talking to the shop foreman at my dealer who I really trust (not the service advisor). He said that on Porsche cars with existing warranties and using OEM spec wheels, the factory will not warranty wheel bearings or suspension components on anything with over 5mm spacers in the front. (rears can go up to 17mm)
That's why Porsche only recommends maximum 5mm spacers in the front with factory wheels and 17mm max in the rears.
The 17mm do kick up a ton of dirt on the sides of the rear bumper so I am going to go with 5mm Porsche OEM spacers all around.
I know many of you have gone with 7mm without problems - but I looked into the price for 7mm spacers with wheel centric flanges and for a complete new set of longer, locking two piece bolts and they're all coming in more expensive than the Porsche 5mm set.
For a 2mm difference, I figure I'll just go with the Porsche 5mm set.
And finally I saw this post from an old timer and that sealed the deal for me. Perfect amount of extension without looking over done...
Originally Posted by Scott & Renee in VA
Love 'em! Installed new Carrera 18" 5-spoke wheels, Pirelli PZero Rossos (225/40 front, 285/30 rear), and Porsche 5mm spacers all around on my 2000 C2 cab. Looks great! Much improved stance with the 285s vs the stock 265s, and the 5-spokes really look aggressive (used to have 18" turbo-looks). Enjoy some photos!
Old 11-12-2013, 12:22 PM
chsu74
chsu74's Avatar
Would not even buy 5mm spacers and waste the money. I would buy wider rubber instead to get the benefit of extra grip and look as extra. IMHO
Here is my old car sitting on 7mm rear and 15mm front FVD spacers
https://rennlist.com/forums/8451182-post8.html
Old 11-12-2013, 02:59 PM
roadsession
ALways admired your car and the stance!
Anyway I know I'm probably being too conservative but I really do like the various 5mm spacer pics I saw online from at least a half dozen owners...so I placed a call to Sunset Porsche in Oregon - they have it on sale for $300!
Will post before/after pics
Old 11-13-2013, 08:00 PM
redridge
redridge's Avatar
+1 on 7mm, 15mm FVD... another thing to consider is the lug nuts, make sure it is a 2 piece utilizing a floating collar.
Old 11-15-2013, 12:03 AM
tarzancoe
tarzancoe's Avatar
If running oem specs on wheels, 7mm front and 15 rear will be perfect. If you put 15 on front, the tires will rub the inner wells at full lock, unless you use a heat gun on the wells and then it should be fine. 7/15 is the easiest.
Old 11-15-2013, 01:30 AM
redridge
redridge's Avatar
not true, many people run 15mm up front and 7mm rears... with no issues.
Old 11-15-2013, 06:55 PM
perryinva
perryinva's Avatar
I also bought the FVD Brombacher hubcentric 7MM (actually 7.5mm, IIRC) all around, and they come with high quality longer bolts as part of the price, as well as the screw that holds the spacer in place to the disc for when you remove the wheels. Smooth as silk, no extra balance wieghts were even required. Highly recommend. I've got a post with pics on here somewhere. Especially noticeable if you lower your car at all, like I did with PSS9s.
Old 11-15-2013, 11:32 PM
roadsession
Thanks all.
I decided to follow my master techs advice and be conservative
Went with the Porsche Oem 5mm kit with new security bolts.
Hopefully weather is good enough tomorrow for me to install them and put the winter set on
Old 12-02-2013, 01:38 PM
roadsession
Here are the winter tires and wheels w/ the new Porsche 5mm spacers.
One thing I noticed about the OEM 5mm spacers is that they're not simply flat. The area around the center hole is machined to allow the hub's flange to protrude all the way out to make sure the wheel is hub centric.
Old 12-02-2013, 03:52 PM
alpine003
alpine003's Avatar
Personally 5mm isn't worth the hassle/cost on a factory offset wheel for the 996. The main reason to have spacers is for looks and I don't really see 5mm making any noticeable impact in that department. But if you're happy with them, that's all that matters.
Old 12-02-2013, 04:46 PM
redridge
redridge's Avatar
^^^ +1
5mm-7mm are flat and uses the cars built in flange to be hubcentric. They are to thin to make with a hubcentric lip because of this flange. So, it's not a OEM Porsche magic thing. 14mm is where it starts for the spacers to have its own flange to be hubcentric.
Old 12-02-2013, 05:01 PM
onewhippedpuppy
onewhippedpuppy's Avatar
Originally Posted by pfbz
You might check out OTIS Inc. for wheel spacers and bolt kits. CNC machined in the USA, Alcoa 6061-t6 billet aluminum, hub-centric, wheel-centric (only spacers over 7mm), and top quality wheel bolts...
They sell them in different spacer width, pairs of two, sets of four, etc. but for example, a set four spacers and twenty bolts is is $260. A few dollars more in black instead of natural aluminum.
If you are using OEM wheels, OEM size tires, on a narrow body 996, I think 7mm in the front and 14mm or 15mm in the rear is about right (link to four spacer kit)
I went with the Otis 7/15 mm package with bolts and couldn't be happier. Huge improvement in looks, no vibration. Quick shipping from Otis, they even called me prior to shipping to insure that I was running OEM wheels so they sent me the correct seat lug bolts.
Quick Reply: Oem 5mm spacers or aftermarket 7mm?
