Build Log: NineEreven Turbo NB
#91
Hey Capt, sorry i should have explained more. I know how the wastegate system and all that works, but not sure how that could help me narrow down the problem. all it does is remove boost from the equation but I think boost is what the source of the problem is. I know I can't tell until I try it, but what I am saying is I am pretty sure from what I can tell with the car already, it will drive fine out of boost.
#92
I figured you knew how it worked, but now those playing along at home can know also.
The reason you'd want to try it is because it will confirm that boost is causing the problem. If you can get higher into the RPMs without issue with no boost, then you know it is related to airflow. Of course, there are a bunch of boost-related issues that could be the problem.
You could have a boost leak somewhere after the MAF (intake manifold, intercooler piping, etc.).
The MAF could be dirty/bad.
Something could be up with the fuel system.
Tune could be bad.
Lots of things.
Tune could be bad.
Lots of things.
#93
My guesses were literally all the things you just listed. Looks like I will have a busy weekend. Hope I can get it sorted out soon. There is a huge event march 21st that I want to be able to go down and woop on some unsuspecting cars.
#94
Captain Obvious
Super User
Super User
Do a systematic check of everything by first removing boost. You'll be amazed what you think might be the problem and what will end up beeing the actual problem. Don't guess, confirm everything to be 100% sure it isn't a contributing factor. Do only way to do this is if you systematically go through everything one at a time.
I'm not sure if you can show up in a 996 and suprise anyone. Most people expect a 911 to be fast.
#95
1) secondary air pump located in left side of bay was unplugged. Oops.
2) some how the o2 sensors on both sides of the cats were very loose. I could spin then with my hand loose. That I think I owe to a buddy helping me.
3) the big one - there was a rip in te hose after the MAF before te turbo letting unmetered air into the car. It was a small 1.5" rip or so but in sure that had a lot to do with it.
I am still looking through everything. Plugs look good, no black or white build up, injectors don't show any leaking, and I don't see anything else major.
I do have a small oil leak on the right side of the car that only leaks when the car is running. It's in the top near the alternator area. Thoughts?
#98
Oh, the tear is pre-turbo? I think it's still enough to cause an issue, but a hole like that would definitely cause issues if that was a pressurized hose. I take it you haven't had a chance to drive the car again yet?
#100
Those ducts suck and I planned to replace them anyways I just wanted to verify functionality of the kit and it seems those were the weak links. Anyone buying the kit should ditch them asap and not even bother testing with them.
BTW your drop looks great. Saw pics on IG
#101
Ok, I got the car together last night after picking up the pieces from the paint booth. I had all the maple wood in my car painted black as well because that wood trim is just god awful.
It looks absolutely incredible in person. I can't wait to go out and get some real pictures instead of the crappy camera phone pics.
#104
This has nothing to do with the car but I highly recommend The Eagle bar/restaurant downtown Cincy. When I visit I got there - the fried chicken is unbelievable.
#105
Thanks. I want to take it to my local cars and coffee this saturday so Hopefuly I can snag some pics of it out of the garage finally. Then I am heading down with a few buddies badass cars to Water By The Bridge and you can expect me to ***** out photos of it from there.
I live basically downtown. I will definately check that place out. I am surprised I haven't heard of it. hmmm
