996 Forum 1999-2005
newb question about tail light bulb.. did searc
Old 02-12-2014, 12:31 AM
SubzeroX
SubzeroX's Avatar
Default newb question about tail light bulb.. did searc
even looked in the manual. But there are too many different numbers for parts on different sites and designations and i dont know jack about them. what bulb do I have to get to replace this? the break lights work.. this is just the normal tail light that comes on when lights are turned on.
please and thanks!!
can someone post a link of the exact bulb I need to order? thanks!
Old 02-12-2014, 01:41 AM
Mark I
Mark I's Avatar
https://www.sylvania.com/en-us/appli...s/lrgmain.aspx
Old 02-12-2014, 05:25 AM
6ta1
6ta1's Avatar
looks to me like the rear fog light, no? only one is supposed to work
Old 02-12-2014, 10:54 AM
bretm
bretm's Avatar
The good news is that this is probably the easiest job on the entire car. The OM shows how to do it - just take a 10mm socket and remove the two bolts on the inside of the tail light (when you open the rear bonnet) and the tail light slides right out towards the rear.
I forget the exact bulb, but you'll see the number on it when you remove it. They might be in the OM as well. Pep Boys has a great selection of bulbs - the exact brand and model that is called for.
Fwiw, they're so cheap that I just replaced all of them when I did this a few months ago. Only a couple bucks each.
Quick Reply: newb question about tail light bulb.. did searc
