Illustrated single DIN radio install walkthrough
I replaced the factory head unit with a single DIN Kenwood that has HD Radio, Bluetooth streaming and telephony. My car is a 2002 996 with Bose audio. I wanted a clean look, so I installed the Bluetooth microphone in the factory location to the left of the instrument cluster. Also, the rear USB connector attached to the head unit ends up in the cubby. I figured that I would take pictures as I went along to benefit myself in case I want to revert to stock or need to do it again for some reason, and I thought they might be useful for others.
Here's a picture of the completed install (the cassette holder was removed when I took the photo and I plan to replace it with another storage cubby.)
This is the download link for the walkthough (it is a 120MB PDF due to all the pictures.)
I see from another post that you DJ so I think you would appreciate at least a speaker upgrade which I plan to do at some point. I will also look into replacing the amp.
tcc (10-15-2019)
