First Gear Issues
Rat Balls
First Gear Issues
I had my clutch replaced about 3k miles ago. Flywheel was fine. All good until the last few weeks when it started slipping in first gear. Even stalled it a few times getting it moving or pulling into the garage. Also noticed a significant decrease in acceleration just in first gear. Otherwise, shifting is fine 2-6. Scheduled to take it back to my Indy next week, but wanted to get input from you guys before I take it in. Clutch, flywheel or tranny? Thanks!
Received 1,102 Likes
From a full stop, put it in second, give the engine some revs and take off. If the clutch is slipping you will know. Always machine the flywheel when replacing the clutch. 3K is very low mileage for a clutch to go bad again, so something is wrong with the install. Not the tranny, it is mechanical and will not "slip". Probably glazing on your flywheel.
First is usually the last gear that it slips in. Maybe the slave cylinder or throw out fork is sticking?
If it is slipping that bad the Dual mass flywheel is probably toasty.
Sometimes it is hard to get shops to resurface a DMS flywheel. I had to shop around to get my first one done and it worked out fine. I replaced it ~20k miles later when I replaced the IMSB with the ceramic one.
By slipping, you mean that RPM increases without a corresponding increase in output at the wheels, right? Seems odd that you'd be more likely to stall when first is slipping.
Only you and the shop know whether the flywheel should have been addressed when your clutch was replaced. Mine was resurfaced, but I was showing normal slippage (some 3rd, mostly 4th and 5th gear under acceleration), rather than the really odd first-gear slipping you're describing.
What do you mean by "decrease in acceleration?"
Rat Balls
How does the clutch "feel"? I am asking because this could be any number of things: clutch slave cylinder sticking, bad release bearing, clutch fork is bad, clutch is bad, glazing on the flywheel. The point being this isn't going to go away and the only solution is to have the tranny pulled so all of this can be checked. For the shop that did the original work...what did they do (replace)? And will they fix it under warranty? What type of clutch did they install..OE?
Rat Balls
Captain Obvious
Super User
Super User
Don't drive it anymore or you can wipe out the disk. Get someone that knows a bit more about cars and have them test it and get their oppinion on it because your description is difficult to understand.
Gonzo, your description sounds odd. Does everything work fine if cars on a lift? Can you post a vid of whats going on?
Rat Balls
Sorry but you cant do (not recommended by LUK) this on the DMF. You must replace it which should have been done anyway when the clutch was replaced. Not sure of your mileage but every clutch related part should have been replaced.
Yea, best is to take it back to the shop. Whatever it is, I'm pretty sure they need to open up the transmission to find out more as obviously your clutch is slipping and that can't be a shift linkage or external problem.
You know, it is possible to install the clutch disc backwards but Im not sure what symptoms that would cause. At this point we're all WAG'ing. We would really like to see and/or hear whats going on.
Gonzo, can you smell the typical slipping, burnt clutch smell?
Rat Balls
Thanks again. BTW KK...I kinda missed you while you were gone!
