Can you tell what this noise is?
Found a loose exhaust clamp and tightened and got rid a cat rattle. Still have this one. Thoughts?
Here is video.
Here is video.
No possible source jumps out at me. This leaves oh about a zillion possible sources though…
Wish you could have just let the engine idle.
You are at the vehicle so let me ask you the questions. Do you have any idea where the noise is coming from?
It would be worth the cost -- and some places do not charge for this -- to get the car in the air and give a listen under the car and pinpoint where the noise is coming from. If this can be pinpointed and it can almost 100% of the time this goes a long way to helping ID the source/cause of the noise.
However, I'm reluctant to suggest you should run the engine any.
Thus have you dropped the oil filter and poured its contents out in a *clean* drain pan and given the oil a thorough check for any scary metal (or other material) debris?
Does engine exhibit this noise immediately upon a cold start? Or does the engine have to idle a while before the noise comes up? Or does the engine have to be fully up to temperature before the nose appears?
Does the noise change if you depress the clutch or if you put the Tip in gear?
If the noise is present with the engine cold you can remove the belt and start and run the engine long enough to verify the noise is present or not. What you hear or do not hear determines your next step.
Be sure you note very carefully -- take pics or make a sketch, and take notes do not rely upon your memory -- the routing and direction of rotation of the belt before you remove it so when you reinstall it you install it correctly and so it rotates in the same direction as before.
While you have the belt off give each accessory drive pulley a check for excessive play. Really though my experience is any play. If there is a problem with one of these you will know probably because it has some play while the other accessory drives have none.
Check the idler roller bearings and tensioner roller bearing for any signs of distress. Too much play. Signs of a compromised seal.
The next vid, I let the engine idle a little. It does not make the noise while idling.
When I did the oil change, the rattle came from a loose clamp at the cat and I tighten that down. That rattle went away. I guess initially it was a combination of rattles.
Get someone to help you give gas. Put a long screwdriver between your ear and each cat. Sounds like cat rattle (core inside broken) or muffler shield rattle to me. Sounds external but it's not easy to tell from the video.
If not those, just follow Macster's suggestions above.
The easiest check is on the heat shield. On a cold engine feel in for a bolt attached each end. If the far one (out of sight) is missing then it could be a loose heat shield. The noise to me is giving off a (tinny sound) and the heat shield over the Plugs is very light weight in nature.
I did make some progress. I used binder clips to clip some of the loose pieces in the bumper and found a nut missing holding a shield attached to drivers frame. Then I shimmed one of the clamps holding the cat to the engine. Now I have some not so loud rattles at 1500-2000rpm... ugg. This all started after I took the car to have an safety inspection done.
I'm also gonna go with something in the exhaust. I would try taking it off and run the motor to see if you can reproduce the noise. What the hell crawled into your garage at 42 sec into the video?
Maybe a lizard?
