Crunching the Class Action numbers.
#76
#77
I keed. I keed.
The aftermarket ceramic hybrid bearings are supposed to be more reliable than the OEM bearing. Even if you could get a dealership to install an OEM bearing, why would you if more durable options are available?
If you have a single-row car and you want to install a permanent "Solution," there's a guy who can help you out with that. I have a dual-row car, so my options include (a) doing nothing, or (b) upgrading to the hybrid bearing. I chose the latter - even though my dual-row car is less likely to fail, my indy and I decided to retrofit anyway.
#78
Received 1,095 Likes
Everything dies and everything mechanical will break eventually. There are no permanent fixes...for anything! Your nice car will end up in the junk yard someday and that's a reality. Life is short...and nothing lasts forever. Moving on....(insert screaming exit!!)
#79
Couldn't agree more. I tried that logic once too, and someone interpreted that as "you think that 996's are awful and that's why they'll eventually break. Heretic!"
All machines have a lifespan / MBTF, a fact with which some folks seem incapable of coping.
#80
John, the replacement dual row ceramic hybrid bearing that installs into an original dual row bearing car like yours is recommended to be replaced at 75000 miles not 50000 miles. That it what I was told when Jakes shop did mine. As SCHN3LL said if your engine is an original dual row bearing it can not get the IMS solution which is good forever and possibly longer! Your choices no matter how many times we go over this are to either do nothing or do the upgrade. Whichever way you go the odds are greater that an uninsured motorist driving drunk will crash into your car and escape before you get an upgrade or the stock bearing goes out.
#81
The current popular solution of replacing the factory bearing with a limited life aftermarket bearing leaves me wanting something better in terns of a solution.
Yet even as well known as those issues are, there are still those that ignore these things and then cry when one or the other craps out and the motor is toast.
It's a much cheaper car and a much cheaper motor, but the problem is the same. Parts rarely last as long as intended in the real world and people ignore the conventional wisdom that would save headaches.
It's called preventative maintenance. Every car needs it. Some more than others and some is more involved and expensive than others.
If replacing the IMS bearing is so easy, why not have a Porsche dealer do it with an OEM bearing?
What I have come to accept lately, however, is that our car no longer gets driven enough to "feel safe" (I'm going on year three of "I'll change it with the clutch", but I've still got another 10-20k on this clutch). For those cars I do believe Jake's solution has an advantage over the OEM bearing and is a better choice.
I'm still not planning to change it out until the clutch needs to be done and we'll see how much it is getting driven at that time.
#82
#83
GDI, In my opinion you were lucky to have a 2001 that still had a dual row bearing in it. Like Jake said you can't be sure what bearing they have until the engine is apart. Good luck with your newly acquired car. Mine is also newly acquired and I couldn't be happier.
