Engine Case Flaking - Is this a problem?
I just got my engine cases back from the machine shop where they were sleeved. The sleeve job looks great, but I noticed some aluminum flaking inside the case. Does any one know if this is an issue?
Captain Obvious
Super User
Super User
Did the shop try to clean it up? In the second picture, looks like someone was in there with a die grinder. What did the shop say about the flaking?
Former Vendor
That case appears to have been porous and repaired at the factory. The machine shop should have consulted with you about this. I'd hope they know what this means.
I didn't talk to the shop yet and didn't notice it when I left the shop as the 2 case halves were joined and wrapped...r the shop told me that they boiled the cases to clean them up, but that obviously wouldn't do it...it does like a die grinder was involved though.
Now I'm not saying porosity would develop. Based on my exposure to (non Porsche engine) castings it would not surprise me if a few engine castings come from the factory with some porosity (or suspected) porosity addressed. It has been my observation in a foundry there is at least one welder who's job it is to weld up castings that would otherwise be scraped due to casting porosity.
Generally if the engine was porosity free before it was disassembled and cleaned up it should remain porosity free afterwards.
Maybe.
The cleaning could find a weakness in the casting -- most likely where the casting had been repaired before -- and open up a new path for a possible leak to develop over time.
However, even the small risk of a leak developing at this critical point warrants I think a real need to get this addressed properly so there is no chance of any porosity to develop and allowing the coolant to go anywhere outside of the the cooling passages.
JR is right. The shop should know what to do about this. And you should ask the shop.
Update
I spoke with my machine shop and he concurred with JR and Macster in regard to a possible repair at the factory...He said he didn't notice it at all when he was working on it and was surprised to see it because this is something he would have taken care of had he seen it. He thinks the cleaning process may have exposed it after all the work was completed.
He didn't think it was a big deal because both sides of the wall touch oil so porosity would not be an issue, and the fix is to just smooth it out to remove any possibility of it flaking a little more and possibly contaminating the oil in the future.... He said he can use something like JB Weld if I insisted, but he thought it wasn't necessary...
