996 Forum 1999-2005
Front suspension thunk/rattle when warm
Old 01-21-2015, 11:34 PM
DWS964
DWS964's Avatar
Default Front suspension thunk/rattle when warm
The car has developed a noise in the left front suspension. Well, in the left front corner. I originally assumed it was a loose sway bar link - that kind of noise. The odd feature is that the noise is not present when the car is cold. It only shows after being driven for many miles and something warms up. During the recent cold blast when the daytime temperatures were still around 10F, I did not hear the noise at all. Now that the temps have gone above freezing, the noise is prevalent after driving the car for a while. I sometimes wonder if the noise is more of a "binding" noise/creak than a loose thunk/rattle.
I have noticed a problem with what I assumed to be the front springs binding when turning at low speeds. (once again, this was more noticeable when warmed up). I suspected back upper shock mounts, or that perhaps the thrust bearings were missing from the installation of the PSS9 suspension (common mistake apparently).
I put the car on the lift, and sway bar and control arm and shock bolts are tight. I might drop the shocks out this weekend to see if the upper mounts or thrust bearings are bad.
Suggestions?
Why would the noise increase with temperature?
Old 01-22-2015, 12:03 AM
johnireland
johnireland's Avatar
Bushings and other rubber/plastic parts have a certain elasticity to work. Cold temps they tighten up and are not as flexible. Warmed up and they start to give more.
Old 01-22-2015, 01:10 AM
fpb111
fpb111's Avatar
Mine does the same thing on the right front..
I haven't really investigated it yet.
I did change the sway bar drop links because one had play. That has not solved the problem.
2003 C2 Cab 57k miles
Old 01-22-2015, 01:23 AM
Spokayman
Spokayman's Avatar
I will be following this thread with interest, as my C4 seems to exhibit the same symptoms.
I would describe the noise as a rattle, located in the right front, and is only heard when the car has been driven for awhile.
Old 01-22-2015, 08:47 AM
dporto
dporto's Avatar
Received 1,154 Likes on 791 Posts
Both C4's? Only after warm up, sound coming from front corner(s)... my guess would be something related to the front drive - differential, CV joints, hub, wheel bearing (you'd probably get some whine/grind with this as well) etc.
Old 01-22-2015, 09:14 AM
DWS964
DWS964's Avatar
I have thought about CV joints - but the sound is not quite like the clicking/binding sound that I recall from my FWD Honda's with really high miles, torn boots, grease gone, worn out.. outer CV joints. But then, I really noticed it this AM at low speed coming into the parking lot, but both while driving straight and when turning. Perhaps more frequently when wheels are straight ahead.
I will get a thunk on as little as the 3/4" lip entering my garage. Still unsure if it is a loose rattle, or a binding noise.
The 996 is relatively low miles - 65K, CV boots all nice, etc.
I do not recall seeing many front differential problems being mentioned here.
Driving me nuts.
Old 01-22-2015, 03:03 PM
Spokayman
Spokayman's Avatar
Could be AWD related I suppose, but in my case the sound is caused by suspension movement from a rough road. It is not a rotationally induced sound like CV joints or a wheel bearing might cause. Only suspension compression/rebound will cause the noise.
My right front CV joint was replaced a couple of years ago by the PO and everything visually seems well intact and tight.
Old 01-22-2015, 03:59 PM
5CHN3LL
5CHN3LL's Avatar
I have some clunky rattles in the front on my C4 that are not serious enough to investigate. I have removed the FWD components (half-shafts, differential, drive shaft), so I'm pretty sure they're not to blame in my case.
Old 01-22-2015, 07:07 PM
white out
white out's Avatar
Simple list off the top of my head:
strut top hat
ball joint
tie rod end
My girlfriend's beetle had a clunk that sounded like a bad bushing or failing part from above. Replaced everything and the car still had it. Ended up being a bad inner CV that was loose and with no load would clank around (in neutral), but with load was silent. If AWD, might be worth checking out to see if your CV's are making any noise.
Old 08-26-2018, 12:06 PM
dmw
dmw's Avatar
Did anyone ever figure out what was making the noise? I have the same issue. Changed sway bar links and strut mounts. That helped but the noise is still there, especially on hot days after the car has been driven a while.
Old 08-26-2018, 02:46 PM
808Bill
808Bill's Avatar
Any rubber suspension part could be to blame. They all should be replaced by now!
Old 08-26-2018, 03:57 PM
Schnauzer
Schnauzer's Avatar
My bet is that it is the lower control arm (dog bone). It is cheap enough and easy to replace. In my case I could tell this was the problem by applying light breaking which would stop the noise. To get the clunk going the car needed to be driven about 10 miles. I did a realignment after the install but the numbers did not change so maybe I could have saved that money.
Old 08-26-2018, 04:20 PM
fly4beer
fly4beer's Avatar
Was right outer tie rod on my car. Symptoms only after warmed up. Depending on outside temp it took shorter or longer to exhibit. Porsche Tech did put some fat there somewhere 1 year ago, still symptom free so far. (2001 C4)
Old 08-27-2018, 12:00 AM
dan_189
dan_189's Avatar
Had the same issue, clunk when warm - replaced all for of these - clunk gone. They are near impossible to visually diagnose - unless you can see where its been hitting which is difficult.
Old 08-27-2018, 10:34 AM
Clark78
Clark78's Avatar
Had the same issue on mine (C2), only rattled when warmed up. Replaced the inner steering tie rods on both sides and the sound was gone. This part:
https://www.ebay.co.uk/itm/OEM-Inner...-/182664941841
/C
Quick Reply: Front suspension thunk/rattle when warm
