Cooling Fan Resistor
So, a couple of weeks ago, I noticed a slightly warmer running temp. The needle was reaching the middle of the 0 in the 180 marker. And usually this would be when driving at low speeds.
My initial instinct was something having to do with the cooling fan. So, I pulled over and listened and as suspected, the passenger side fan was off while the driver side was blasting away. I reached out to one of the RL members and he helped me do some trouble shooting. (Thank you!)
Fuses and relays were OK. So the primary culprit was the cooling fan. However, my brother suggested that we test the resistor and know and behold the fan works but the resistor is bad. So instead of buying a new fan, he is suggesting replacing the resistor if it makes sense. I've attached a picture.
1. Where can I find and buy this?
2. Has anyone done this before rather than replacing the entire cooling fan?
No personal experience but if it's this one, it's $120 (a pure crime if you ask me), may as well get the Bosch fan ($170).
http://www.pelicanparts.com/catalog/...pg5.htm#item12
https://rennlist.com/forums/996-foru...l#post11342583
That guy did it for $5 with a generic resistor from rodeo shack.
I've done the opposite, replacing a bad fan, keeping the good resistor.
Funny. I had the same thing happen on my Mini Cooper (aka BMW). I used one of these:
http://www.amazon.com/Amico-Aluminum...wound+Resistor
Less than $10 vs $170 for a new fan. It kind of makes the decision, doesn't it?
Those regular power resistors with the proper wattage will work. The only concern I have is how to weather proof it properly given the location of the resistors and how they are exposed to the elements, rain, road salt, etc.
Of course the above shouldn't concern us Californians
Those regular power resistors with the proper wattage will work. The only concern I have is how to weather proof it properly given the location of the resistors and how they are exposed to the elements, rains, road salt, etc.
Condom maybe?
Former Vendor
Considering how often that area gets splashed, you definitely need to protect that resistor.
Definitely check the fan operation first. Run a positive and negative 12V to the fan direct connector and see if it runs. I had a '97 Boxster that had two bad fans, so they can fail.
This one says "can be used in atrocious environment" ... It's an anodized aluminum shell, so it should be ok as long as you make sure the leads are well covered/protected.
This one Amico Aluminum Shell Chassis Mounted 100W Watt 0.33 Ohm 5% Wirewound Resistor: Single Resistors: Amazon.com: Industrial & Scientific
We did. We supplied power directly to the fan through the connector and it worked just fine.
As electronics are not my strongest suit I am also interested in adverse effects. For example can one expect adverse affects on other electronic components if not using the factory resistor in this case?
