Noticed a rod knock noise in my car...
#80
Teardown inspection showed the cylinders were pretty badly scored up. My best guess is this was from extreme cold starts, since I was commuting in the car all year-round. The pistons would heat up faster than the case and the metal would expand to the point where it was an interference fit with the cylinders. I wasn't ready for the expense of an engine rebuild, so I sold the car as-is to someone who felt they could do it cheaper. I don't know what the final outcome was.
As much as I'd love another 996, I've had a job change and now work from home. I rarely drive anywhere - unless I go to the track, in which case I'm driving a truck and trailer!
Just one more (12-29-2020)
#81
Yes, this is an old thread... (and I do miss my 996)
The following 4 users liked this post by Mike Murphy:
Byprodriver (12-31-2020),
James_03C4S (12-29-2020),
paddlefoot64 (12-29-2020),
TexSquirrel (12-29-2020)
#82
Former Vendor
Cylinder finish is one of those conditions.
#83
#84
That was my guess too.... at least the primary cause. I think in some pics I've seen scoring on just one side of the cylinder. Not sure how that could happen...a distorted cylinder and piston growth maybe. my question to you though is.... How did you drive it? Did you baby it till it warmed up (small throttle openings and let it spin up) or did you extract torque right away?
#85
At home, it would always be parked in the garage, so it would never get that cold. But I would have to leave it parked outside at work (2-days at a time) - it was not uncommon for me to have to do a cold start at zero degrees. I think the coldest I saw was -15. I would let it warm up a few minutes before driving, and I'd never go over 3k RPMs until the water temp was up to operating temperature. But in that extreme cold, I think the damage happens very quickly.
#86
just looking at expansion numbers roughly. A 100 mm piston could expand .004 inch for a 50 degree c delta
#87
That's pretty significant. I'm sure someone could do the math: start with a cold engine at -20C, if you know the thermal mass of the piston and the thermal mass of the case/coolant/oil and apply a 2000C temp in the cylinder to warm it up, how far apart do the thermal gradients get? My guess is you'll get the piston up to at least 30C before the case is up to -19C.
#88
#89
thats why I was asking about driving style. when you extract torque, you dump much heat into the piston. rpm, not so much
