Noticed a rod knock noise in my car...
Well, during the last 2 or 3 engine starts I've noticed a some oil smoke - which was never there before. And today I had to back the car out of the garage and while it was idling in the driveway, I noticed a distinct knocking sound...
The poor engine might not be much longer for this life. However, I've had the car nearly 8 trouble-free years and 55k miles. It's a '99 C4.
We'll see what happens, and I'll keep everyone updated.
I was just looking on ebay, and there are 3.4 liter Boxster engines in the $4-5k range... Any reason why that wouldn't be a "bolt-in" - accounting for the accessories and intake plumbing?
Just guessing but putting the engine in the middle of the car vs hanging out the back might create many different issues. Exhaust, motor mounts, transmission placement, coolant system, I think looking for a 911 transplant would be more efficient.
Jake, can you elaborate on what you mean by driving in cold temperatures? Are you referring to cold starts or even driving in cold temperatures even after a warm start? I assume your point is bore scoring and how cold temperatures impact it... What is 'cold' in your textbook and what advice would you give to people who drive their cars year round in 4-season climates?
Indeed - lots of times... What's your theory?
Yes, of course - that's what I mean by "accessories". I mean, is the basic long-block the same from an M96 Boxster as an M96 996. Clearly, if I take the engine out of my 911, I have the exhaust, intake, engine mounts, etc. ready to bolt onto a new donor.
From the pic, is your car showing a little over 169k miles with original engine?
Jake is asking because these engines typically will score bores more frequently if driven in the cold, well cold startup that is.
Was your car sitting up for a while? It could be a lifter as well instead of a scored bore.
Mike
Mike
It doesn't sit much - I drive it at least every other day... but that does include some super cold weather.
Usually a lifter is more of a "tick" noise, but this is definitely more of a "knock" noise... Oil pressure is still good; coolant temp is good; it's running well otherwise... But something is amiss, I can just tell.
Or with my Boxster a converter brick was loose. It would generate a deep bass knock upon cold start. Warmed up the thing would buzz like a heat shield was loose.
Once warmed up I can even hear what sounds like rod knocking from my Turbo. Turns out the noise is from the gear box, the rattle of the gears on the input shaft. When I depress the clutch pedal the noise goes away.
Captain Obvious
Super User
Super User
Rod knocking is rare. Before you blame a rod for the noise and condemn the engine be sure a water pump isn't failing.
