Has IMS solutions ever failed
#31
Former Vendor
Jake it's the same shop I've pm'd you earlier.
http://p3autokrafte.com/
These are the credentials of the mechanics
http://p3autokrafte.com/about/
I know they are not certified by LN engineering, however I am comfortable going with them, given their credentials.
#32
#34
Better remember this member in case he comes back a few months from now and says his engine blew up even after he installed the "Solution".
#35
Are you saying they installed the IMS Solution for $926+tax more than merely putting the old IMSB back in? Or $926+tax more than an LN ceramic bearing retrofit?
#36
#37
#38
Former Vendor
This is why engines that are to be retrofitted MUST be pre- qualified. If they fail pre- qualification, the issue must be addressed before moving forward.
The reputation of the product I have over a decade of my life invested in lies in the hands of every installer in the world who does this job. If a failure ever occurs, its only a "failed part" that we are expected to stand behind, no matter if the engine passed or failed a pre qualification.
Here's a directive about IMS Retrofits where bearings are already failing
http://imsretrofit.com/bearing-already-failing/
You MUST understand that the smaller particles are what matter more than the larger ones in this situation!!!!! Smaller pieces become suspended in the oil and delivered to the wear components within the engine, and the IMS Bearing. Bigger pieces of debris settle to the bottom of the sump here they are collected and they seldom go anywhere.
I need to get the VIN of this vehicle to be placed on the "blacklist". Please message it to me.
#39
did this work with a bearing that was shedding
#42
That's exactly what OP did but one can't just install retrofit IMSB or Solution these days without prequalification and expect everything to be rosey.
#44
Former Vendor
The only IMS Bearings we will retrofit are those that are "perfect".
The failing bearing doesn't just take out the new bearing, it also chews all the rest of the internals up as they are fed with oil laden with contaminants.
Those who think their OEM oil filter will save them, are absolutely wrong, too.
#45
I smell BS here.... Why would you sell the "solutions" in the open market then? You said you don't even know how many " solutions" been sold by LM engineering. So, if you don't even know that, then how do you know who bought it and who installed it? If you are genuine with what you are claiming here, wouldn't you track every "solutions" sold?
