996 Forum 1999-2005
downshifting or braking? The debate...
Old 07-22-2016, 04:32 PM
  #31
Slakker
Slakker's Avatar
Originally Posted by Woodman71
Ohhhh, I looked at my option codes and apparently the original owner didn't order those.
That's because they weren't available for yours. They were only an option on the 996 C2S.
Old 07-22-2016, 05:28 PM
  #32
DTMiller
DTMiller's Avatar
As usual, you get it.
Old 07-22-2016, 07:14 PM
  #33
jgm911t
jgm911t's Avatar
I blip downshift to rev match the RPM's, assuming that save the clutch and wear and tear on the transmission. I don't really heel toe it, any advantage if your not on the track?
Old 07-22-2016, 08:52 PM
  #34
mrjonger
mrjonger's Avatar
Originally Posted by Slakker
It first came up when the IMS failures weren't happening on the heavily tracked aggressively driven cars like you would expect, but on the ones that were babied. Turns out the variocams were designed to excel at high RPMs, which is why you feel the nice boost 3k+, but not so much at lower RPMs.
My mechanic said something similar, but mine sees a fair amount of traffic. I do question really it's better to keep the RPMs up even when it's in first gear in stop and go traffic. I asked him specifically about this and he didn't change his answer.
He suggested keep it under 3K when warming up, and upshifts should be done in the 4-6K range.
Old 07-22-2016, 09:16 PM
  #35
Triple Black
Triple Black's Avatar
In my imagination, I'm always on the track
No, I cannot think of any advantage - other than the selfish pleasure it brings.
Old 07-22-2016, 10:32 PM
  #36
jgm911t
jgm911t's Avatar
I started practicing rev matching downshifting about six months ago with my 330CI and 986 Boxster. I'm pretty good at it now but find the 996 harder. I find I have to depress the accelerator further than the other cars. Anyone else experience this?
Old 07-22-2016, 10:51 PM
  #37
Cuda911
Cuda911's Avatar
What's with all this shifting and braking baloney? Why wear out tranny, clutch, or brakes?
Just toss out the road anchor.
Old 07-23-2016, 02:48 PM
  #38
wwest
wwest's Avatar
Downshifting puts the braking/drag at the rear, helping to keep the car aligned with desired direction of travel in conditions that warrant.
Not especially needed with ABS....
Old 07-23-2016, 09:19 PM
  #39
Jeremy Hazeltine
Jeremy Hazeltine's Avatar
Downshifting is cleaner, at the rate my pads make a mess. Hell i can barely leave the driveway without brake dust!
Old 07-24-2016, 03:43 AM
  #40
jayzbird
jayzbird's Avatar
Think of all the heat your brakes generate instead being transferred through your clutch and transmission. The only real case for compression braking is on steep downhill grades, and even then you should be rev matching your downshifts and just using the engine braking to hold speed.
Old 07-24-2016, 11:43 AM
  #41
911 carrera blue
911 carrera blue's Avatar
and this is why you change your clutch every 20000 miles!!!!!
Old 07-24-2016, 04:04 PM
  #42
Slakker
Slakker's Avatar
Or not. These clutches are pretty solid and if done properly down shifting places no additional wear on the them than any other gear change. Riding the clutch or dropping the clutch is what shortens their lifespan.
Old 07-24-2016, 08:00 PM
  #43
sparks259
sparks259's Avatar
Brakes are for slowing the car, transmissions are used to accelerate the car. Case closed.
Quick Reply: downshifting or braking? The debate...
