downshifting or braking? The debate...
What's your opinion about downshifting. I have always downshifted at intersections and now I'm wondering if it's really a good idea.
It's a lot of work in my 2001 996 C4, and maybe it's not great for the tranny and engine.
What do you do?
What do you do?
Downshifting is fine but it's not an efficient form of braking. Your brakes do a much better job of that. If you heel/toe when you do it, it's a little easier on the synchros and great practice for the track. But heel/toe is a lot tougher (for me at least) with light braking because the brake peddle is further up. But if you really want to take care of these engines, try and keep the RPMs above 3,000 for the most part. The only time I did below is taking corners in 2nd gear but then I ease on up to 3k and then liberally add throttle from there. This prevents undue stress on the variocams.
What's less expensive Brakes or a transmission Don't use your transmission as a brake - even though it's fun- you have the best on the planet , use them!
I learned how to drive with downshifting as an integral part of the experience. I find it very difficult to only use my brakes.
