Finally my 996 is coming
it arrived yesterday from GA to MI, snowing when it got here ��
took it out for a bit of a spin today even though it was only around 32 and windy, loving it already
had to swap out the side markers to clear the yellow looks terrible on white i think
the truck was taking this to St Louis, sounded and looked amazing ! its a 71 Dino GT
Congrats,
You will get a lot of "do this", and "do that" from the guys here....
however, clear your front and rear water drains ASAP!!!!
Takes 10 minutes. If they are at all clogged, one good down pour of rain or when you wash it you use to much water, you can cause thousands of $$$'s in damage to vital electronics.
Just one cab owner looking out for another cab owner.....
PM me if you want help on how to, or search under "water drains".
Congrats,
Congrats,
The 996.1 with lowered springs (H&R springs or coilovers) has an amazing stance, in my view ... plus the added handling benefits. Highly recommended as a 2nd mod following pumpkins swap!
Very nice car! Congrats!
Congrats, You will get a lot of "do this", and "do that" from the guys here.... however, clear your front and rear water drains ASAP!!!! Takes 10 minutes. If they are at all clogged, one good down pour of rain or when you wash it you use to much water, you can cause thousands of $$$'s in damage to vital electronics. Just one cab owner looking out for another cab owner..... PM me if you want help on how to, or search under "water drains".
Originally Posted by Woodman71
Hey Rolex, dumb question but when I have the hard top on the cab does rainwater still get in those drains? Thanks!
Realize there are front drains and there are rear drains. The front drain are indeed on either side of the battery. I not 100% sure but if the front drains are clogged and water collects I don't believe water gets inside the car. But the battery compartment floods and affect the brake booster and other stuff in there.
I believe (guessing until I take a look) when the hard top is on, the edges of the top are farther out and the water dips down the side of the car. Whereas when the soft top is up the top material is inside of the edge and forms a channel where the water collects and flows down the "waterfalls" as they are known. The waterfalls lead into a collection tray which holds about 2 or 3 cups of water. These collection trays have a hole at the bottom with a tube that leads to the rear fender well of the back tires where the water exits safely.
These rear drains are the ones that can flood the interior. Either the outlets inn the rear fender wells get clogged from road debris or the holes at the bottom of the collection tray clog. Either way if the collection trays overflow the water spills out. And believe it or not these trays are in the interior of the car so the water goes right into the carpet floor. If enough water over flows (and it doesn't take much) it finds its way under the drivers seat and floods the electronics there.
These rears drains must be checked by taking off the rear tires and getting behind the plastic fender wells to check the outlet drains. And taking out the rear speakers which exposes the "waterfalls" and the collection trays.
Iy usually takes a lot of time for these drains to clog due to small amounts of dirt building up. But the nightmare scenario is if a piece of insulation foam or some rubber strips which are located above them fall off and land in the trays and block the holes. You can just have cleared your drains but of this happens it is immediate and the tray will overflow in a good rainstorm or heavy washing of the top.
This why I always check mine every 3 months or so and looks for any foam or other materials that might look like is coming loose. If so I pull it off or reattach it securely.
