996 Forum 1999-2005
Need help identifying a wire connector
Old 04-12-2017, 04:44 AM
Fyrftr50
Fyrftr50's Avatar
Default Need help identifying a wire connector
Connector under pocket in center stack. Wire colors are brown, yellow w/black stripe, green w/black stripe and red w/green stripe.
I found this lonely connector after removing the pocket in preparation for moving the climate controls to the bottom slot (Double Din install).
Does anyone know what it is for? I don't want to leave something important unconnected but I couldn't find any socket near that area.
Old 04-12-2017, 05:48 AM
Millemiglia
Millemiglia's Avatar
Could it be for the phone module in PCM?
Old 04-12-2017, 07:26 AM
fpb111
fpb111's Avatar
Phone prep plug.
Brown =ground, yellow/black = telephone mute, green/black = switched 12v, red/green = un-switched 12v
Old 04-12-2017, 08:07 AM
Hurdigurdiman
Hurdigurdiman's Avatar
two of the wires are live permanently and the other two come live with the ignition switched on. Very useful for my on board Police radar detector. I use the side that comes live with the ignition. Also a good pick up point for the day time running lights which I installed to the ignition side. The plug does not attach to anything on my car although at one time it did supply a worn out radar detector which I removed along with a ton of old wiring. The permanent side of the plug I use for a fused switched double connector which I in turn use, for my GPS with forward looking camera and recorder.
Old 04-12-2017, 12:54 PM
5CHN3LL
5CHN3LL's Avatar
The phone connector, as others have stated, is an awesome resource if you need switched power.
If you need a LOT of switched power, use the phone connector's switched +12v and a relay.
Old 04-12-2017, 06:27 PM
Fyrftr50
Fyrftr50's Avatar
Default Thanks for the assistance!
Thanks so much for your help everyone! Now I can reassemble my stack without fear of something not working.
Old 04-12-2017, 08:00 PM
JayG
JayG's Avatar
Not to be an ***, but a search would have answered your question
Old 04-12-2017, 09:54 PM
808Bill
808Bill's Avatar
What would those key search words have been?
Old 04-12-2017, 10:56 PM
KoB
KoB's Avatar
Probably would've figured it out by Googling "Porsche 996 center stack connector" and reading a few posts. But I agree, it wouldn't have been very intuitive.
FWIW, I believe that this is the connector that mates to the one in the center stack:
http://www.ebay.com/itm/252389052709
I used one for the wiring to my auto-dimming mirror, with a couple extra connectors for a radar detector that I never got around to installing. It made for a clean installation, although whether or not that's worth $20 is certainly open to debate.
Old 04-12-2017, 11:26 PM
Schnell Gelb
Schnell Gelb's Avatar
If you do not use the "Telephone Connector" , it is a good idea to tape over it to prevent it shorting to ground. It will blow E6 fuse.
Quick Reply: Need help identifying a wire connector
