Lock passenger door manually
Hey guys
02 C2
both my my keys fobs have given up the ghost - no remote locking
i am ok with manual locking but when I turn the key to lock from outside only the driver door locks
if I am inside the car and press the lock switch both doors lock
no beeps / no codes
im sure there's a way to program the car to lock and unlock both doors when I manually lock with the key
can someone point me in the right direction?
02 C2
no beeps / no codes
igrip (08-23-2023)
Both doors should lock and unlock with the key. Someone else here had a similar problem recently but I don't know the outcome. I'll see if I can find the thread but in the meantime try searching for it.
Edit - The thread I was talking about doesn't provide a resolution. Curiously, it was also an '02.
With the driver door open, press the lock button in the console, then get out and close the door. (Works on my '03; I'd be surprised if it didn't work on an '02.)
I tried this prior to posting and confirm that it doesn't work on my car
Basic Sponsor
Hey guys
02 C2
no beeps / no codes
02 C2
no beeps / no codes
Take a look at the link below, it may help you troubleshoot. If you need more details, please post a Comment just below the article and someone will get back to you with specifics!
http://www.pelicanparts.com/techarti...nd_Handles.htm
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Problem is that without any codes being thrown it is hard to know what is going on... OP if you turn the key in the driver's door twice are you able to lock the passenger door? I assume you've replaced the keyfob batteries? Many auto parts stores have a tester for the remote keyfob. It is quite simple-minded: it just detects common frequencies and flashes an LED at you.
Thanks for this - posted a question
Turning the key twice doesn't work either - thank you. Yes new batteries tested - keys are now just totally dead regardless. you're thinking it's just the LED?
Are there no codes being generated by the alarm module?
Does your central locking button actually function? I just looked at a car in March that had similar problems...the symptoms seemed to added up to an immobilizer issue in my mind or some other electrical gremlins.
Remote didn't work. Turning key in driver lock didn't lock the passenger side. 2 turns in the lock did not result in the beeps indicating internal alarm off. entry lights did not come on when doors opened. central locking button did not function. Could not raise or lower the cab roof by holding key in lock/unlock position
