996 Forum 1999-2005
997/996 Key compatibility
Old 05-05-2017, 02:30 AM
lowpue
lowpue's Avatar
Default 997/996 Key compatibility
I have a set of 997.1 keys from my totaled 997 GT3....Was wondering if I can reuse them. Can you program a 997.1 Key to operate a 2000 996. Same goes for a 997 to 986.
Old 05-05-2017, 08:39 AM
Millemiglia
Millemiglia's Avatar
If the 996/986 key fob internals fit inside the 997 key fob then just shift them over.
It should work.
Old 05-05-2017, 11:21 AM
lowpue
lowpue's Avatar
yeah...but the buttons don't line up...trying to see if I can actually program the fob to work?
Old 05-05-2017, 12:22 PM
Ben Z
Ben Z's Avatar
This article shows how to do it
Old 05-05-2017, 01:17 PM
JayG
JayG's Avatar
You can't sway the internals form a 996 key to a 997 fob. The switches are I a different configuration
996 - triangle
997 - inline
It may be possible to buy a new 997 fob and have a 996 programmedfor it. I have no idea if the electronics are compatible. Its doubtful a dealer will do it and you pretty much have no choice but a dealer to program a car for a key. In addition to needing a PWIS or PST2, you need to have the double super secrete codes from Porsche
Old 05-05-2017, 05:39 PM
lowpue
lowpue's Avatar
THe article shows going from 997.1 to 997.2...My question is 997.1 to 996.
Originally Posted by Ben Z
Old 05-06-2017, 10:08 PM
fpb111
fpb111's Avatar
I have purchased these heads used, on EBay, at different times and swapped my stock key guts/blade into them with no problems. (From a 2003 C2 and 2004 Turbo) Actually I had to file the edge of the blade down to get the lock to engage on one of them. YMMV
https://www.ecstuning.com/b-genuine-...g/00004400083/
For as long as the listing lasts.
http://www.ebay.com/itm/2-New-Replac...3D191053161319
Quick Reply: 997/996 Key compatibility
