996 Forum 1999-2005
Do I have to remove the center console to replace the e brake switch?
Old 07-06-2017, 04:49 PM
AzDropTop
AzDropTop's Avatar
Default Do I have to remove the center console to replace the e brake switch?
Top will not go down...was working fine. Noticed with the e brake on the dash does not indicate it is up. After a bit of reading seems this is common. Curious if I really have to remove the console to do this job. That seems like a serious amount of work to replace this tiny part.
Old 07-06-2017, 07:19 PM
AzDropTop
AzDropTop's Avatar
After a bit continued searching the answer is yes. Yes I do. Job done and getting the console out was not as difficult as it looked like. E brake switch replaced and a how to coming soon...
Old 07-06-2017, 08:30 PM
wyovino
wyovino's Avatar
Good job! Looking forward to your right-up of the DIY. As a fellow Cab owner I figure it's just a matter of time before that will be on my list.
Old 07-07-2017, 09:16 AM
Dans996tt
Dans996tt's Avatar
Replaced mine on the Boxster with a cheap eBay switch and it only lasted 6 months. Maybe better idea to use OEM switch.
Dan
Old 07-07-2017, 12:07 PM
808Bill
808Bill's Avatar
+1 on OEM electricals...
Old 07-07-2017, 12:31 PM
Schnell Gelb
Schnell Gelb's Avatar
Yes the console needs to be removed.
I bought the switch from Sunset. The older switches(EBay) have a different part number. Careful !
Great opportunity to upgrade your worn shifter
Old 07-07-2017, 03:58 PM
AzDropTop
AzDropTop's Avatar
Thank you sir. Here is the link to a How to Video I just uploaded. Hope it helps!
I got the part from the dealer and I'm not sure why an OEM part wouldn't be used since it is only $7
Quick Reply: Do I have to remove the center console to replace the e brake switch?
