996 GT2/GT3 Forum 1999-2005
996 GT3-RS Top wing / Spoiler on 996 GT3
Old 08-15-2018, 02:06 PM
Nickshu
Nickshu's Avatar
Default 996 GT3-RS Top wing / Spoiler on 996 GT3
I'm sure this is a Noob question but I cannot find the answer upon searching. If one wanted to add the 6-GT3RS rear spoiler/ top wing onto a 6-GT3 does the RS wing it just bolt on top of the existing 6-GT3 rear decklid using the same decklid/uprights/attachment point as the standard GT3 wing? Or is it an entirely different rear decklid on the RS? If not what other options exist?
Thanks in advance.
Old 08-15-2018, 02:45 PM
sp0da
sp0da's Avatar
Yes, the factory RS wing blade does bolt right up. Other options in that same design include Getty and MShaw. I believe Getty has the RS wing blade in the factory length as well in a larger size.
Old 08-15-2018, 02:59 PM
Nickshu
Nickshu's Avatar
Thanks that answers my question!
Old 08-15-2018, 03:07 PM
cgfen
cgfen's Avatar
I tried to buy one from Mike Shaw, but he is either mostly retired or just doesn't care anymore.
Getty sells P/N GT3-03 for this application.
Both Getty and Shaw will admit, if pressed, that either the CFRP or Fiberglass wing, will require cosmetic attention prior to installation.
Maybe Ken W, a RL'er from Canada, that has purchased the getty wing will chime in.
He is happy with the purchase.
Old 08-15-2018, 04:52 PM
RossP
RossP's Avatar
There is also the real thing from Suncoast for $7900.......
https://www.suncoastparts.com/produc...RSSPOILER.html
Old 08-16-2018, 11:32 AM
CME
CME's Avatar
Wow these things were approx. $3k when new back in the day!!
chet
Old 08-16-2018, 11:40 AM
Burger
Burger's Avatar
Someone should order the Scopioneusa.com wing to let us know how good/bad it is. lol
Scopione Wing
Old 08-16-2018, 02:14 PM
rodneyr
rodneyr's Avatar
Yes, the genuine RS wing is definitely a direct bolt on using the same hardware. That wing is just about the most expensive part on my car
Old 08-17-2018, 10:21 PM
spiller
spiller's Avatar
I believe GMG also offers an option in OEM quality for about 3K?
Old 08-18-2018, 10:25 PM
cs81
cs81's Avatar
Suncoast group buy?!!!
Old 08-19-2018, 12:26 PM
KenW
KenW's Avatar
Default Getty Wing
Yes indeed, I bought a Getty RS wing and it was a pleasant experience doing so.
I suffered "wing envy" for 11 years, finally got that fixed!
The wing comes out of the mould, it might need a touch up or two at the edges, then it is best to clear coat it.
Looks great and functions very well, I am pleased and recommend Getty.
Old 08-19-2018, 07:56 PM
enthusiast
enthusiast's Avatar
See my do it yourself install.
Old 08-24-2018, 07:46 PM
996FLT6
996FLT6's Avatar
It's plug and play but tell you removing those painted plastic covers to get to bolt is pita. I wrecked them(why they made it so damn difficult to remove wo damaging the covers is beyond me). Anyway if it happens when u try to pry them out is can order a new painted set from Eric the plug guy.
Old 08-24-2018, 08:31 PM
Matt Lane
Matt Lane's Avatar
Just to chime in here, yes, Getty is a VG choice. Like Ken, mine required some prep and work to have the clear applied with no pin holes etc.
I'd say I got a 90% finish, cost me $500 to do the wing and end plates. It requires many coats of clear and sanding. I am only annoyed that my shop did not do what I asked for - the leading edges should be filled, masked, and painted black for a perfect slick finish. I guess we are quibbling here.
Unfortunately, GMG had supplier issues and no longer offered the GT3 spoiler last year. Probably for the same reasons, these are hard to finish 100% perfect.
More unfortunately, Manthey racing probably had the best stuff along with the factory - also NLA as of last year.
Getty is fine, just find a shop that will spend the time (or not) to get it to your personal finish expectations.
Cheers
Matt
Old 08-25-2018, 05:08 PM
sp0da
sp0da's Avatar
Anyone have experience with or know if the FVD option is factory? https://www.fvd.net/us-en/FVD5129960...bon-fiber.html
Quick Reply: 996 GT3-RS Top wing / Spoiler on 996 GT3
