High number of range 2 ove revs
Would a rev limit change by a tune really mean much of anything? If it is raised to 8400 RPM, then range 1 would be <8400 RPM and range 2 would be >8400 RPM right?
A car with a raised rev limit might theoretically have spent some time in the 8200-8400 RPM range just by hitting the rev limiter.
But 8400 RPM is not dangerous for the 996.2 GT3 engine, as I understand. Of course, if you do a money shift it's going to show up as range 2 either way.
The other possibility is that a tune might change the rev limit to say 8400 RPM, but the DME is still recording range limits at 8200 RPM.
If that were the case, you might end up with a lot of range 2 over-revs that are really only 8200-8400 RPM, and not that concerning.
Thanks for the data point @mnwild
The car had a PPI done and this was the result of the scan. The ECU thought occurred after and now hoping they can test the rev limiter today to see if the car will stop or go past.
This car was used for PCA club racing since 2009. It is not street legal, so if you remove time spent idling in pits, and driving through the paddock, it has endured probably 5 hours of either qualifying, sprint races, or an enduro since the last range 2 event at 666.6 hours. I would like to think that if something bad was lurking it would’ve showed itself under that kind of stress. But maybe that is wishful thinking.
mnwild (12-30-2020)
I would be leery of a car with those type 2s so close to current operating time.
Booth9999 (12-30-2020)
A race car?!
I would bet there is a tune allowing for the non-mechanical overrevs. Compression and leakdown test would make me feel much better regardless of if there were 1 or 100 instances shown in the ECU.
I agree with above two posters. And I also agree that if the redline has been increased it would give me a little more comfort because although over revs will still be logged it will be much easier to hit a zone 2 overrev if the rev limiter is not kicking in at the stock level. It just means that there was not necessarily a mechanical overrev, which is the scary kind. Problem here is that the last zone two was relatively recent. With that said if compression and leak down is good and the car drives well and the price reflects all the risks I’d say go for it in the car otherwise suits your fancy.
I also agree that an ECU mod shouldn't change how the Ranges are counted. The only issue is that you would see many more Range 1's.
I note some inconsistent discussions on the RPMs for Range 1 and Range 2. I was under the impression that Range 1 is over 8200, but below 8800. Range 2 is over 8800. That is:
996 GT3
RANGE 1, 8200-8800
RANGE 2, 8800 and over
I'm sure a math wiz can confirm this, but at 10,000 RPM = [10,000 / 60 *3 ignitions per rev] = 500 ignitions per second. 12,000 ignitions / 500 ignitions per second = 24 seconds -> that's a lot of time past 8800 RPM.
IMO, having 12,000+ Range 2 is objectively a lot. I figure most people start to get nervous when there are over 1-2 seconds of Range 2 [a thousand or so on the counter ]. That long and I'd be thinking money shift. 5 to 2 is usually the culprit. I mean, with the rev limiter, there's really no other way to mechanically get the engine to exceed 8800. Sure, a car could get a few Range 2 some other way, but over over 20 seconds of Range 2? I'd be VERY nervous.
-td
Trucker
The maximum count for each range is 65535, so there may be 70,000 or 700,000 or 7,000,000 million actual counts on range 1 but the counter cannot count anymore than 65,535.
Also, the 996 DME is trigger happy and it just counts. It has been a PITA and has caused discussions since 2001...
Correct. It is the total Range 2. As I noted, there is no way to tell when those happened other than the last one happened approximately 6 hours ago. That is - there is a chance that ALL of them happened then. That's why I would be worried. *owner: "WHOA. Oops, that was a money shift. Time to sell the car"**
996 GT3
RANGE 1, 8200-8800
-td
996 GT3
RANGE 1, 8200-8800
-td
I had the shop that did the PPI test the rev limiter and they found it to be working at the stock limit.
thanks for all the inputs. I have decided to pass on the car.
@Tom Loder I think you made a wise choice to pass
Maybe this has already been said but there are documented 996's with ECU glitches that count range 1 overrevs as range 2. Also some that show swapped range 1 and 2 data. There is a thread on this around here somewhere.
Since you're passing on the car it's a moot point but my GT3 has some minor bounces off the limiter in Range 2. When we were preparing to pull the engine for the coolant pipes I had a leak down and compression test at about 51k miles on the car and it came back at less than 1% across all the cylinders. The shop actually did the test twice because it just seemed impossible. These engines are pretty stout.
Tom Loder (12-31-2020)
interesting, thanks for sharing. I wouldn’t want to hope for a glitch as the cause. Is there a way to find out if it was a computer error or just owner testimony?
