What Tire Pressure Are You Running?
For everyday and mountain road driving? What's the pressure you're shooting for front/rear to start the day, cold tires?
Especially with stock or stock sized 18" wheels.
sp0da (06-24-2022)
Alignment is track/street at approximately kussmaul settings. Wear is quite even across the tires with mixed track and street use. Got almost 20k kms from my last set of rears. I started searching for pressures because the car rode terribly with 39r - the back end always felt like it wanted to step out and I had brand new tires, guard diff, fresh alignment, and new engine mounts. The drop in rear psi made a huge difference for me - IIRC credit goes to powdrhound for the pressure starting point. Does it understeer? Relative to a 39psi tire, definitely. But I'd rather have more total grip and keep that rear end behind me 🙂
Tires are stock size yoko ad08r, ohlins r&t now but driven mostly on stock shocks that were just meh.
