996 GT2/GT3 Forum 1999-2005
Factory anti-roll bar settings
Old 02-17-2005, 02:49 PM
bobej
bobej's Avatar
Default Factory anti-roll bar settings
Just out from under my new 05 GT3 and everthing looks good except nuts on anti-roll bars in rear look used. Car has had an alignment at dealer. What are the normal factory settings? My fronts are set at the most foreward position, rears are set in the second hole from the rear.
Many thanks, I need to know where to start before changing.
Old 02-17-2005, 03:28 PM
Holger B
Holger B's Avatar
I think the factory setting is one from stiffest both front & rear.
The proper setting is very subjective based on a number of factors including how & where you drive, tires, alignment, etc. I went one notch softer in the rear (as some others here have also done) and that works well for me.
If you haven't done it already, make sure you re-torque them and put on some loctite. Almost everyone has had the front ones work their way loose, creating a clunking sound over bumps.
Old 02-17-2005, 04:20 PM
gtdrei
gtdrei's Avatar
Holger B is right. The Factory setting is 1 from stiff in front and rear. With the stock suspension, I ran 1 from soft in front and 1 from stiff in rear, with -1.5 and -2.0 camber. This was primarily an AutoX setup to get more rotation. It's very much a personal preference, and has a lot to do with how you use the car.
Old 02-17-2005, 06:17 PM
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
Bob-ej I run factory setting in the front i.e. one hole from the highest (higher is stiffer) and one down from the factory setting in back. This allows me to get on the gas earlier ini high speed turns with less risk of power oversteer. I trail brake in slow turns to overcome the understeer. Note - autocross settings as described above might be dangerous on a high speed track!
Rgds,
Old 02-17-2005, 06:43 PM
gtdrei
gtdrei's Avatar
Bob, I agree. Too much oversteer for high speed and smooth surfaced tracks. 1 from stiff (F) and 1 From stiff (R) are much more stable settings for track work.
Robin
Old 02-17-2005, 08:19 PM
RayGT3
RayGT3's Avatar
Question, full stiff is closest to the bar itself, soft is furthest from the bar?
Old 02-17-2005, 08:40 PM
NJ-GT
NJ-GT's Avatar
Yes
I run Full Stiff front and one from full stiff rear at the track.
For autocross, I keep the rear bar in the same position, move the front one to full soft.
Old 02-17-2005, 09:13 PM
Yargk
Yargk's Avatar
The way to remember is just by imagining trying to twist the bar yourself.
Old 02-18-2005, 02:03 PM
vegasgolf98
vegasgolf98's Avatar
or, the longer the bar the more flexible it is , the shorter the bar the stiffer it is.
Quick Reply: Factory anti-roll bar settings
