996 GT2/GT3 Forum 1999-2005
Airbag cutoff jumper??
Old 09-16-2008, 05:17 PM
JMeager
JMeager's Avatar
It's not rocket science. Where ever you put the resistor, plug a multimeter onto the airbag module onto the same pins and measure the resistance. To be honest, it's probably only looking for an open circuit so the difference between 1.8 and 2.8 versus infinite resistance isn't a consequence.....
Consider that you are all right!
Jeff
Old 09-18-2008, 09:39 PM
TurboCup87
TurboCup87's Avatar
Jeff
Just where is the resistor placed? Do you tap or splice across airbag wires? Are there only two wires? Does someone have a picture or good description to help us garage DIYers out? I really don't want to screw up a harness or cause a short. I've been living with it, but we have an annual state inspection and they won't pass it. I'd like a long term fix. TIA Kyle
Old 09-19-2008, 09:49 PM
4porsh
4porsh's Avatar
Took the car to the shop today to have the resisters put in, did not go will they need more time will do it on Monday. They needed a clutch box? that was missing from my car, to get exact reading of which resister. I do not need to buy the box, it just helps them in some way. I know this info does not help you, but it is a job I would not try to do on my own.
Joe
Old 09-19-2008, 10:41 PM
fhp911
fhp911's Avatar
Gang,
This thread was started by me.
There IS a Porsche part and I have ordered it. When I get it I will share all the info.
Fred
Old 09-20-2008, 08:36 AM
LVDell
LVDell's Avatar
Fred...that is fantastic news!!!! Joe, paying attention?
Old 09-20-2008, 11:49 AM
TurboCup87
TurboCup87's Avatar
Originally Posted by fhp911
Gang,
Fred
Thanks, I look forward to hearing about it. Kyle
Old 09-20-2008, 12:30 PM
4porsh
4porsh's Avatar
Yes
Old 09-21-2008, 10:42 PM
Qwickrick
Qwickrick's Avatar
Fred
Please send me the info when you get it. I took Dan D out for a ride with me at Monticello, and when I told him the airbag was still activated, he brought his arms up to cover his chest. And I wasn't trying to scare him!
Old 09-29-2008, 10:12 AM
fhp911
fhp911's Avatar
Listers,
I have now been informed by the guy who was going to get my the Porsche part airbag-cutoff switch that he was mistaken: there is a 993 part but no 996 part. His shop is now trying to create such a part and will keep me advised.
MEANWHILE ... what are the results from the homebrew guys who were going to use a resistor???
AND does the resistor approach
a) stop the airbag from functioning
b) restore full normal operation [including the airbag light going dark] after it is removed ???
Old 09-29-2008, 11:24 AM
TurboCup87
TurboCup87's Avatar
Listers,
Thanks for the news, even if disappointing. If nothing comes up in the next week or so, I'll start working on my own fix ( last track event is this coming weekend). My goal is to have it not set off the Air bag fault light, but still allow airbag function on the occasions that the bag is in. Presumably a resistor wired in series with the wires at the chassis end connector should work. Kyle
Old 09-29-2008, 07:10 PM
va122
va122's Avatar
Ok, I just put in the 1.8 I got from gert and it doesn't work. We put a black sticker over the light.
Old 09-29-2008, 07:15 PM
fhp911
fhp911's Avatar
so va122 didn't have success.
more details, pls:
Did you successfully disable the airbag with the resistor?
Did you successfully re-enable the airbag by removing the resistor?
Was your only problem that the airbag light stayed lit?
TIA, etc
Old 09-29-2008, 08:48 PM
Crazy Canuck
Crazy Canuck's Avatar
Was the computer reset?
Old 09-29-2008, 11:15 PM
LVDell
LVDell's Avatar
That's my thought. Once you apply the resistor the DME needs to be reset by the dealer (PIWIS or PST2).
Old 09-30-2008, 07:25 PM
dan212
dan212's Avatar
Rick -
I put my hands across my chest to hold the harness rather than the door handle because of the side airbags. I've been warned by a couple of people that the side airbag can break your wrist if your hand is there. The harness has me in anyway. I just need to put my hands somewhere where I can hang them and keep them out of your way.
I'm at WGI today and a GT3 hit some armco.. I minor hit, but the side airbags went off on the passenger side..
So a part to temporarily disable the airbags would be very useful.
dan (d)
Quick Reply: Airbag cutoff jumper??
