996 GT2/GT3 Forum 1999-2005
Airbag cutoff jumper??
Old 08-31-2008, 06:44 PM
fhp911
fhp911's Avatar
Default Airbag cutoff jumper??
GT3-ers,
Someone told me that there is a jumper you can insert somewhere in the fusepanel by the driver's left foot which disables the airbags. And it's not supposed to trigger the CEL.
Does anyone know about this? If so, what's the part number?
I'd love to be able to disable the airbags for track use. (Who needs them when you're all belted and HANS-ed in anyway?)
Or is this fantasy??
TIA, CIA, etc
Old 08-31-2008, 06:57 PM
LVDell
LVDell's Avatar
Not sure if it's the same thing I am trying to do running a cup wheel with no airbag. Apparently you can install a resistor on the airbag wires that will trick the OBD/DME (forget which one) that there is an airbag present when here is in fact not one hence no error light or fault code.
Old 09-15-2008, 11:23 PM
va122
va122's Avatar
works great, I just can't remember the amerage
Old 09-15-2008, 11:56 PM
4porsh
4porsh's Avatar
2.8 Ohm 1/2 watt resister, you can use 2.7 Ohm or 2x 1.4 Ohm and connect these in a series. Or get 2 x 5.6 Ohm and connect these parallel, that way you get a 2.8 Ohm.
This info came thanks to Dell and Gert.
p.s. Hey Dell, truck driver said the car may arrive Thurs or Fri
Old 09-15-2008, 11:58 PM
Carefree
Carefree's Avatar
Here is what I found from another member
n/c free advice that would cost you hundreds elsewhere ...
1.8 ohm resister connected in between the 2 wires to fool the computer.
That's what I had my mechanic do and then use the reset tool to clear the error code. Works like a charm.
Hope this helps.
Old 09-16-2008, 01:51 AM
va122
va122's Avatar
1.8 that's it! I knew there was an 8 in there.
Old 09-16-2008, 09:12 AM
LVDell
LVDell's Avatar
1.8? From what I learned from Gert it is a 2.8ohm 1/2W resistor.
I know Joe is about to do this very thing so post up some pics!!!
Old 09-16-2008, 12:16 PM
P.J.S.
P.J.S.'s Avatar
Hope this helps.
+1 -- 1.8 is what Gert sent me when I got the cup wheel from him...
Old 09-16-2008, 12:18 PM
LVDell
LVDell's Avatar
So Gert told you 1.8 not 2.8? I'll have to contact him.
Old 09-16-2008, 12:22 PM
P.J.S.
P.J.S.'s Avatar
My tech measured the "ohms" with a fancy gadget and told me 1.8... I guess he could be wrong... whatever gert sent is working.
Old 09-16-2008, 12:30 PM
LVDell
LVDell's Avatar
1.8Ohm 1/2W?
Old 09-16-2008, 12:32 PM
P.J.S.
P.J.S.'s Avatar
now you are over my head... I will gracefully bow out
Old 09-16-2008, 12:34 PM
4porsh
4porsh's Avatar
I just wrote down what the email from Gert said. Will have the process done in a few days and will post findings.
Joe
Old 09-16-2008, 12:52 PM
LVDell
LVDell's Avatar
I just heard from Gert (I can't tell y'all how fast he is on email!!!) and he confirmed it is 2.8Ohm 1/2W resistor.
Old 09-16-2008, 02:43 PM
P.J.S.
P.J.S.'s Avatar
Damn my idiocy even surprises me sometimes
Quick Reply: Airbag cutoff jumper??
