gt3 seats
gt3 seats
relatively new to this activity
i have a 2004 gt3 with stock seats
car will be used as daily driver but up to 12 de days per season
i need to change the seats
are gt3 seats the best to get the cloth is hard to find is leather ok
there are gt3rs seats that are nice but they dont seem to have the harness holes
are they ok
thank you
are they ok
thank you
thank you
roll bar 6 point harness and hans will be used
having said that the question is are the gt3 seats the best way to go for a 2004 gt3 or are there better ones out there
thank you
thank you
Considering the availability of new or used seats and roll bars, this is relatively good solution IMO for street-ability and limited DE. Key word being relatively. The ideal solution on the other end of the spectrum is a cup car cage. Many on this board started with this setup and eventually moved on to more permanent solutions. If you decide to go this route, be sure the anti-sub harnesses bolt to the CAR and not to the sub-bar that is attached to the movable seat. Good luck!
are they ok
thank you
are they ok
thank you
GT3 seats are certainly OK. You can buy them new or pick them up for about $2000 from somebody else that bought them new. I've never seen ANY GT3 seats that didn't have harness holes. Don't buy a knock off seat. There should be an FIA sticker on the back of the seat. Personally I don't like GT3 seats for street use because they're just not all that easy to get into and out of ... but they're an OK compromise seat. For track use, leather is OK but cloth is a lot better.
Good luck and have fun.
