Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 GT2/GT3 Forum
Old 11-03-2009, 05:47 PM   #1
himself
himself's Avatar
Default Looking for springs
I am running stock springs (which I think are 228#/543#) and want to experiment with some stiffer ones. I currently run R6s, so I don't think extremely stiff ones are going to work - maybe 600#/1000# at most for my test.
If anyone has some stiffer springs lying around I can buy/test, please PM me.
Thanks!
-td
6GT3
335i
E350
00 996
himself is online now   Reply With Quote
Old 11-03-2009, 05:52 PM   #2
Pete
Rennlist F1 Professor Emeritus
PhD, No BS
Pete's Avatar
I've been looking into this too and from what I've been told, a 100 to 200 # spread between the front and rear is desireable.
Pete is offline   Reply With Quote
Old 11-03-2009, 05:58 PM   #3
LVDell
On the "softer" side I would suggest a 550/700 option or if you are set on 600 up front run an 800 in the rear. On the stiffer side I would suggest a 900/1100 option. NO WAY would I run a 400# split.
LVDell is offline   Reply With Quote
Old 11-03-2009, 07:12 PM   #4
himself
himself's Avatar
Quote:
I didn't mean to imply that I want to run 600/1000, rather that those would be the maximums I think my tires could support. I'm good with anything available to try: 600/800, 800/1000, 550/750, whatever
Also, why wouldn't a 400# spread be workable? The factory split is over 300# already.
-td
6GT3
335i
E350
00 996
Old 11-03-2009, 07:17 PM   #5
LVDell
A couple things. First, the 300# split isn't really a 300# split and you are looking at linear and progressive springs. Second, the 400 split would run the front really soft and the rear really stiff. Can you saw lots of oversteer?
As far as you spring choice it should be dictated by roughly three things (obviously more than this but these are the obvious). (1) driving style; (2)current dampers; (3)tire choice (remember, tires have their own spring rate).
What dampers are you running?
Old 11-03-2009, 07:41 PM   #6
Pete
PhD, No BS
Pete's Avatar
IIRC, the front stock springs are progressive. In addition to what Dell said, if there is a large spread in spring rates front to rear your more prone to a lot of nose dive under heavy braking.
Old 11-03-2009, 07:45 PM   #7
LVDell
Pete, other way around.....the fronts are linear and the rears are progressive.
Old 11-03-2009, 09:10 PM   #8
NJ-GT
NJ-GT's Avatar
600/800 for R6 and street use, not too soft, not too hard either.
I ran 750/1000 and felt too stiff for street use. I also ran 450/650, very nice for street, autoX and worked well on tracks.
Get the shocks revalved for the new springs, otherwise you're just running a stiffer car that won't work better, because you won't have enough bump/rebound control for such higher spring rates.
Rennlist Member #: 040525-3732
Autocross and Track Videos
NJ-GT is offline   Reply With Quote
Old 11-03-2009, 11:06 PM   #9
AudiOn19s
AudiOn19s's Avatar
Quote:
+1. If your attempting to re-spring the stock dampers you can't go more than about 10% up or down without a revalve otherwise the shock won't be able to control the spring
the spring rate question in general is a good one though. 600/800 is what Moton suggests and seems to be what most run however some very quick cars on here were running different rates than that. 171mph had 600/900, rad had 750/1000, I think I even remember one setup with more front spring than rear. Lots of variables in there though. The advertised rates on my 996 were 450/900 but I always doubted thouse were truely accurate. It was neutral but didn't try to spin out as the rates would make you think
AudiOn19s is offline   Reply With Quote
Old 11-04-2009, 02:24 AM   #10
IPguy
IPguy's Avatar
Does anyone have the wheel rates or motion ratios for the front and rear on the GT3? This would add some more tech to the discussion.
Mike
IPguy is offline   Reply With Quote
Old 11-04-2009, 09:38 AM   #11
Chuck Price
Chuck Price's Avatar
NJ-GT,
I'm not sure what you mean. Are you saying that for street use, or for track use with R6s, you recommend 600/800? When you ran 750/1000, were you using R6s also? Which felt better to you, if that were the case?
Chuck Price
2004 GT3 White
'96 Polar Silver 993
'87 911 Red
Chuck Price is offline   Reply With Quote
Old 11-04-2009, 10:18 AM   #12
LVDell
Depends on what your use of the car is going to be. Street more? Track more? 50/50? etc?
As another data point I have run several different spring combos on mine and the latest setup was 900/1100 and while it wasn't unbearable on the street is was definitely not comfortable any time I hit road that was imperfect.
I would run something like 550/700 or 600/800 if the car will get a descent amount of street time. As Rad said (which is why I asked what dampers you were running) you need to make sure and revalve yours if they are still stock.
Old 11-04-2009, 11:21 AM   #13
Pete
PhD, No BS
Pete's Avatar
From what I understand, you also have to insert a tender spring and some kind of hat or top perch?
Old 11-04-2009, 11:35 AM   #14
NJ-GT
NJ-GT's Avatar
Quote:
Optional, but really recommended to avoid noises and more important to avoid coil binding and possible strut rod damage when an unloaded wheel suddenly get loaded (transitions) and the spring hooks the bottom of the upper hat.
Reuse your stock hats, use gemini isolators (very nice stuff) and zero rate tenders (ultra thin and decently long). 60mm I.D.
Old 11-04-2009, 12:57 PM   #15
va122
va122's Avatar
remember to use the correct spring lengths. I run 6" in the rear and 4" in the front but I have custom built Motons and I'm super low. Lex at Moton recommends 6"in, he built mine personally.
run 600/800 BTW for Hooters, you can go 800/1000 but I wouldn't stand it on the street. Personal preference on the split. Lex says he likes a 300 split so people don't get in trouble...
Victor
Nationally certified PCA instructor.
va122 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
