classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
Rennlist Member Join Date: Apr 2006
Has anyone tried running the R888 in a 265/35 up front on stock wheels/offsets? Did you have to change the setup much to get them to fit (I run -3.0 degrees with shims)? Also, is the 305 or 315 the better choice for rear in the R888?
TIA, -td |
#2 |
User
265 is wider than recommended for that wheel, but it might work, don't know about clearance issues. With -3.0 front camber, it doesn't seem that you should be having understeer problems to any great degree, and I would be a bit concerned with introducing earlier off-throttle oversteer. But it might work fine, sorry, I'm not really helping you.
#3 |
Rennlist Member Join Date: Jan 2005
R888 also has 255/35 available too. Recommended rim width for 255 is 8.5-10 (stock rim width is 8.5"). Why not try this first?
And I think most ppl run 315/30 in the rear. And def think this would be better match esp if you are thinking of running 265 in front. |
#4 |
User
Agreed... BTW, these tires run BIG, so on stock wheels moving up in size, a 265 will be like a 275 almost 285, way too much sidewall and flex IMO!
#5 |
Rennlist Member Join Date: Jun 2005
I'll second the 255 being the better choice. I ran 255 r888's on 8.5" wheels on my C2 and they worked well but even looked a bit big in 255 on that wheel. Anything bigger on that wheel and I'd think your carrying extra weight around and making front feel sloppy with very little benefit.
FWIW I think Rad ran 275 RA-1's on stock wheels for auto-x but said they were not good for track events in that sizing
#6 |
Rennlist Member Join Date: Jul 2006
I have run Hoosier 255's that are really 275s and the fit just fine
Victor Nationally certified PCA instructor. |
| Thread Tools | |
