Problem with Brake Pad Install?
Hi guys,
I use pagid's yellow pads on front and I noticed that although I still have left a lot of pad material the pad sensor is almost touching the disc as you can see in the picture bellow. Is something wrong in the installation of the pad or the sensor?
Regards,
Ipe
Regards,
Ipe
Nevermind.... My friend just advised me that this is not the sensor and this will never contact the rotor as the pads are used. No worries then...
Cheers,
Ipe
Cheers,
Ipe
GT3 player par excellence
if you are talking about the cylindrical thing in front of the pad, that piece is FIXED wont move. the pistons PUSHES your pad closer to the rotors as pad wears out. your installation looks correct.
^ yes, they have pad sensors.
most of us short it out and zip tie it out of way. save time changing pads, also, those little sensors aren't that cheap if you keep replacing them.
-td
