Front brakes setup / configuration
This year my friend and I, will be running GT3's.
GT3 MkI track only
> on OEM rotors with RS-14 pads
GT3 MkII Cup track only
> on Cup rotors with RS-19
Due to cracked rotors, we need to renew our setup and
are looking for input on the best setup, still maintaining std. calipers
- best pads?
- best rotors?
- floating rotors?
Thx!
GT3 MkI track only
- best pads?
- best rotors?
- floating rotors?
Thx!
Someone recently asked a similar questions here...
This is what is on my car and works so good that at my last track outing the car stopped so well that it spun my front tire on the rim.. 1/2 around the rim in a day!!
2 Piece Brembo Floating Hat.. Increased Diameter Rears. Stock Calipers with SS Brake Lines.
Pads are Pagid RS32... First tie with those and they were good. On previous cars I've used and really liked Hawk DTC 60 & 70 for track duty.
There are many choices, depending on what you want to spend. The cheapest are ATE Cayenne rotors for about $120 each. DeMan rotors are about $330 each. PFC are $550 (approx) with new rings $330 thereafter, or $1000 with $550 for replacement rings depending on what type you want. Brembos are close to $2k, I think, with replacements (I don't know). GiroDiscs look very very built, and are closer to the expensive side of the spectrum. Check out the Rennlist for vendors. The main difference between the cheapest and most expensive is weight. I don't know how longevity compares, but I'd expect the more expensive to last longer. I've used PFC, DeMan and now have Cayenne mounted and will try them in a few weeks for the first time. I don't know if I'll notice the weight difference.
Pads...some use PFC, 97-01-06 or Pagid Black or yellow. Pagid blacks and PFC 01s have great bite, and are harder on rotors. Pagid yellow and PFC 06 are enduro pads and last longer, and have adequate bite for my needs.
What performance characteristics do you want? How much do you want to spend?
Given the fact that almost any brake set up will lock the brakes, which would provide maximum torque between the wheel and the tire, the fact that your tire rotated on the wheel is more of an indication that there was excess lubricant applied when the tire was mounted, than a testament to the "power"of the brakes.
The difference between a "good" brake set up and a "bad" one is not the ability to stop the wheel from rotating in absolute terms. It has more to do with the ability to modulate up to the limit of lock up, its ability to dissipate heat, to function well under a range of temps, to last a long time, to weigh less, to cost less, to respond to pressure in a relatively constant way in different temp ranges, the consistency of "bite" and "release" etc. A tire with better grip will also be more likely to rotate, again contributing to the torque between the wheel and the tire.
To prevent tire rotation on the wheel, a topic discussed on RL, many people recommend a certain type of hairspray to be used as a mounting lubricant, believe it or not. Check search for more details.
Having said all of this, I believe the Brembo brake kit is one of the best in all of the criteria listed above, with the exception of cost.
Whether or not the rotation of the tires was caused by the brakes or the lube.. These things damn near detach your retinas upon braking.
The only downside of the tire rotation on the wheels is that they will not be accurately balanced. Some people don't even balance their race tires for that reason. If you don't feel vibration at high speeds, then I'd forget it.
Considering all the rubber strings that get on the inside of my wheels after one track day....I'm not convinced balancing provides any benefit on track wheels....ever.
Well....maybe it would tell me if the tire was made wrong if it needed a ton of weight to balance it.
Cheers,
Cheers,
I could tell that they were out of balance once off the track... ie. maintaining a speed on the highway of about 65-80mph the steering wheel shook like hell. That is when I really noticed it and brought the car by my shop.
My kuhmos rotated around the wheel.
Never noticed on the track but highway driving steering wheel vibrates. Never did nething about it since at the track it wasn't noticeable. I'll do the aquanet next time. Mike
