996 GT2/GT3 Forum 1999-2005
Clunk when releasing brake MK1
Old 08-27-2010, 12:32 PM
JChiles
JChiles's Avatar
Default Clunk when releasing brake MK1
Hello experts,
Car is 996 GT3 MK1 , New pagid pads installed by mechanic.
When I brake lightly like in stop & go traffic, a light clunk from the front is heard when releasing the brake pedal. Sometimes also when applying it light, but more often when releasing.
When I brake hard it does not seem to appear. Also if I have braked hard , it seems like it takes a few light brake "taps" before the sound comes back.
Ideas anyone?
Old 08-27-2010, 12:42 PM
911SLOW
Admin
911SLOW's Avatar
And the clunk disease continues to spread.
Did you install race pads or road pads. Maybe if you didn't install anti squeal shims the pads make the noise.
If its not brake related after all check sway bar bolts and drop links .
John
Old 08-27-2010, 12:54 PM
JChiles
JChiles's Avatar
Orange Pagids , no anti squeal.
Old 08-28-2010, 03:25 AM
Mike76
Mike76's Avatar
Sorry for the non-technical reply but I recently had the rotors and pads replaced in my Mk1 and same thing until he fitted the "pins" that hold they pads. This stopped the rattle. May be the same thing.
Mike
Old 08-28-2010, 03:51 AM
JChiles
JChiles's Avatar
The mech suspected that as well l, but I wanted a second opinion from real experts :-)
I went from original with dampers to pagid without so it feels like strong circumstantial evidence .. Don't really care about the rattle though, just don't want to loose the brakes.
Old 08-28-2010, 08:32 AM
CWhaley
CWhaley's Avatar
It is your pads moving arond in the caliper.... and the noise is from them hitting the guide pin. As a pagid dealer... my experience is the pads/pins can not really be fitted. The pads have a "D" shaped hole that is slighly larger then the pin. You really do not want to go adding bushings onto the pin to take up the gap. This will ultimatly result in the pads binding.
The other is (depending on the compound and if you still have the anit-vibration shims, the pads also have a tendency to heat melt into the vibration pads, which locks them into place) that the pads will need heat too stay seated into the caliper. Once you start driving it around town with light braking your pads "Unbed". When they are not at operating temps... they are like 80 grit sand paper... sanding off all the material that was deposited on the rotor.
Hope this helps.
Old 08-28-2010, 10:57 AM
LVDell
LVDell's Avatar
What is this......front wheel well clunk week???
Old 08-28-2010, 11:02 AM
CWhaley
CWhaley's Avatar
LV... did you ever figure out what your front "Clunk" was from?
Old 08-28-2010, 11:04 AM
LVDell
LVDell's Avatar
Hope to figure it out this afternoon when I get free. I'm on kid patrol right now while the wife throws a baby sower for a friend.
Old 08-28-2010, 11:13 AM
CWhaley
CWhaley's Avatar
Best of luck... I had a clunk on my car when I first picked it up from Dave Maynard... It would only make the sound when turning & Loading the driverside supsension.... Turn out my Strut tower was damaged... Fixed it by replacing with the X74 kit.
Good Luck
Chris
Old 08-28-2010, 11:15 AM
nick49
nick49's Avatar
The noise is a result of using a dual action caliper where the pads have to float. The pad metal backing will make contact with the caliper and a clunk will often be heard. It's perfectly normal and the sound can change or go waway completely depending on the type of pads and the resulting clearance between caliper and pad backing plate. I've actually ground material off the pad metal backing to give more clearance and eliminate dragging pads and a more positive retraction. Many OE pads are designed for a tighter fit or have clips, springs or other devices to eliminate the clunk for street use. This clunk or knock is very common on race cars and is generally the norm.
Old 08-28-2010, 12:20 PM
JChiles
JChiles's Avatar
Thanks guys for the answers.
Old 06-19-2016, 11:52 PM
Abuong01
Abuong01's Avatar
I had the same banging when braking. Pulled the wheel off to find one of the bolts holding the caliper on had fallen out...the top bolt. Does anyone know what size and type of bolt fits the 1985 928s?
Old 06-24-2016, 05:28 PM
NaroEscape
Basic Sponsor
NaroEscape's Avatar
I have the same 'issue'...
https://rennlist.com/forums/996-gt2-...nt-brakes.html
I'm replacing the retainer clips and rebleeding the brakes this weekend...we'll see...
EDIT: Just realized this is a 6 year old thread!!
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
  • Data Analysis & Coaching
  • Drivers Gear
  • Crew Gear
  • Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
Quick Reply: Clunk when releasing brake MK1
