Protecting your wheels question
I now have a tire rack on my trailer. Anyone have a suggestion about what to shim in between the wheels so they don't get scuffed up against each other?
I have used severaL things over the years.
1. Tire Totes to wrap the wheels
2. Cardboard cutouts to place between
3. Old beach towels that would have been tossed.
I don't have any experience with this, but I would be tempted to get some linoleum sheet material and cut to shape. Maybe add some velcro straps from the dollar store to keep them fastened to the spokes.
I was looking for something to put in between my wheels when stacking them for storage. I wound up cutting up yoga mats since I figured the foam would provide a bit of softer cushioning. But now I think a cheaper solution might be those 2x2' foam flooring mats, I think they're now like $10 for a pack of 4 at Harbor Freight.
All good ideas. I came up with an outdoor front door mat from Walmart. Cut it to proper size. Good? Only thing I am concerned about is the pieces flying away at highway speeds although I will ratchet strap the wheels together.
GT3 player par excellence
best is thick cardboard cut to shape, with a hole in the middle so you can push the tire securing rod through. i have tire tote, it protects mainly the TIRE not the wheel. as you put wheels next to each other and drive down the road, they still bang on each other.
^ u know what, you are right.
i run 255/265 front and 315 rears. the scuffs are near the center of wheel where the tote couldn't cover due to wider tires.
I have a set of Blackwatch tire warmer bags if you're interested. You can make a hole and put them on your tire rack. They completely enclose the tire and rim.
http://www.blackwatchracing.com/Tire...Bag-p/1058.htm
I strap my wheels together using a tie down.. Otherwise they will be moving around on the carrier
Cardboard is fine, as long as it doesn't rain. Then you get bits of cardboard covering your hood and I also dug some out of my rads.
I use that plastic corrogated stuff now. Think plastic "cardboard" you can buy at a sign shop or art supply store. Thick enough for cushioning and it won't fall apart over time.
i had a few kneeling pads laying around, about 8 x 18 inches>>>
punch a hole in the center for the lock rod. works pretty well, nice and thick with a built in handle.
