996 GT2/GT3 Forum 1999-2005
Another coolant line discussion
Old 11-02-2011, 06:18 PM
KOAN
KOAN's Avatar
Default Another coolant line discussion
Just had my coolant lines welded. During disassembly, 2 were not tight at the glued junctions. Whew!
Old 11-02-2011, 07:44 PM
gvtesse
gvtesse's Avatar
Sounds like you did it at the right time.
Which ones were coming loose?
cfjan
cfjan's Avatar
Do the fittings need to come out and be cleaned, then re-insert and weld.. or one can just get the engine out and then clean from the outside and weld? Just curious..
Old 11-02-2011, 07:45 PM
KOAN
KOAN's Avatar
Didn't get that info. It was from the welder who had the parts. He did a great job...sorry that they are so hidden.
Old 11-02-2011, 07:46 PM
KOAN
KOAN's Avatar
Because of the epoxy residue, the parts had to be disassembled, cleaned, and then welded.
Old 11-02-2011, 07:54 PM
Serge944
Serge944's Avatar
Chuck is right, you have to disassemble first and clean the glue. It's really a small effort in the grand scheme of things. There is no way you can do this repair with the pipes still attached to the engine.
Old 11-02-2011, 08:15 PM
multi21
multi21's Avatar
Received 2,906 Likes on 1,725 Posts
Is it necessary to drop the engnie to do this?
Old 11-02-2011, 08:25 PM
SH || NC
SH || NC's Avatar
Absolutely Pete. A lot of disassembly needs to take place to get at all the fittings.
+1 to what Chuck and Serge mentioned re: cleaning
Old 11-02-2011, 08:40 PM
KOAN
KOAN's Avatar
There are 8 fittings that need to be repaired.
Old 11-02-2011, 08:41 PM
cfjan
cfjan's Avatar
Thanks for the info.. !
Old 11-02-2011, 09:25 PM
996FLT6
996FLT6's Avatar
Chuck has your shop done nething to prevent the hoses from popping out? Seems like it can be the hose or the press fittings that let's go. Mike
Old 11-02-2011, 09:30 PM
KOAN
KOAN's Avatar
The hose is clamped to a thin aluminum pipe that is glued to the cast aluminum. The hose and clamps were fine. Two of the 8 glued fittings were loose. That seems to be what so many people have reported as the site of failure, and that is why I did this PM.
Old 11-02-2011, 09:40 PM
JohnPG
JohnPG's Avatar
Timely post. I dropped the car off at Conway's last week to take care of this issue. I'm heading down to VIR and figured if I drive 12-14 hours to get there, sure as heck if one of the fittings is going to go it's going to go there.
Got a call from Ken on Monday, he said one of the fitting was very loose. All it took was an easy twist, like pulling the cap off a bic pen to pull the nipple from the casting.
A couple of pics. First shows the fitting was already out of the casting about 1/4 of an inch. The second shows the fitting with the old hardened adhesive.
The third shows the work some mice did before I got the car.
Old 11-02-2011, 09:49 PM
KOAN
KOAN's Avatar
Whew....good catch! A few weeks ago, a GT3 let go at Mid Ohio and caused carnage behind him. I can't believe there is no class action suit regarding this. There are articles in Pano and Excellence, many threads here, etc.
Old 11-02-2011, 10:15 PM
Rovman
Rovman's Avatar
The more i read about this PM, the more i am facing reality that I am going to have to perform this on my car soon. I am setting the car up over the winter for some track time and as much as I want to spend money on other goodies. I think i should spend it here first....... My only problem is I live in Louisiana where, to my knowledge, there are no Porsche shops familiar with this type of repair. I am in the Houston area alot, perhaps I can find a recommended shop in that area. Any recommendations concerning a shop that can perform the welded coolant fitting repair in the gulf south???? If i can't find a shop relatively local i guess i will have to travel a bit.
I used the search function but didnt find anything in my area......
Thanks for any and all info you guys and gals can share....
Quick Reply: Another coolant line discussion
