996 GT2/GT3 Forum 1999-2005
Speaking of Coolant lines - a hose blew
Old 11-10-2011, 02:38 PM
himself
himself's Avatar
Default Speaking of Coolant lines - a hose blew
Check this out. [might take a second to loads]. Photographer at the right place and time to catch my car blow a coolant line (one of the big hoses, left side of the car).
-td
Old 11-10-2011, 02:40 PM
SH || NC
SH || NC's Avatar
Damn. Glad you didn't do any other damage. Video? Anyone behind you? Where was this?
Old 11-10-2011, 02:45 PM
TurboCup87
TurboCup87's Avatar
Lucky boy that there were no walls or close traffic. Let us know which one and the mode of failure. Seems that there are quite a variety. I don't think I'm taking this car to the track anymore unless I get everything welded. Unfortunately, no place at all nearby to do this. C'mon Porsche, do the right thing!!
Old 11-10-2011, 02:47 PM
bobsan
bobsan's Avatar
how many more of these before Porsche acknowledged the issue, send footage to Porsche.
Old 11-10-2011, 03:02 PM
996FLT6
996FLT6's Avatar
Wow- that is some major blowout. Were u on coolant or water wetter? Mine blew on rt side by ac pump. Didnt even know it blew til I got meatballed. I was on water wetter and must have gone thru 2-3 turns wo snapping like that. PAG needs to do something- all gt3's will age and blow on the street and kill somebody. Mike
Old 11-10-2011, 03:09 PM
gvtesse
gvtesse's Avatar
Do you know the specific hose/fitting that blew?
I had my top fittings welded, but I should have also had all the hoses
replaced as well.
Old 11-10-2011, 04:07 PM
himself
himself's Avatar
It was a hose. The one on the left side of the engine. I'll post some pics at the house. About a 3-4" gash just opened up.
Some stills [purchases from Blair]
-td
Old 11-10-2011, 06:28 PM
DHI
DHI's Avatar
td,
Thank-you for the detailed pictures. Useful.
Old 11-10-2011, 06:47 PM
Number54
Number54's Avatar
Great, so not only do the fittings fail, but the hoses fail too.
Is there a solution for this? Better hoses or something?
Old 11-10-2011, 06:52 PM
996FLT6
996FLT6's Avatar
I'm having my fittings addressed and all new hoses. I will still run water wetter. Mike
Old 11-10-2011, 06:53 PM
Serge944
Serge944's Avatar
Same exact thing happened to Brad last year at Thunderhill. I was one of several cars behind that got taken for a ride.
Old 11-10-2011, 06:54 PM
Serge944
Serge944's Avatar
Hoses fail eventually... It's also important that they are clipped/seated in well. Give the hose a good tug after installing.
Old 11-10-2011, 08:00 PM
JohnPG
JohnPG's Avatar
-td
Glad you where able to stay on the track and it looks like no one was right behind.
Happened to me too. Other side hose. Same size gash, same violent explosion from the look of your pics. Luckily I was in the middle of a straight and was able to get off track before the breaking zone. Another reason to run with water wetter.
Happened on the first session of a three day event. Couldn't find a replacement part in stock at any of the dealers in the state. That ended a three day event. All for a 38.00 part. Replaced both sides and now I carry spares.
As Serge says, hoses need to be replaced/checked.
Old 11-10-2011, 08:54 PM
PAULUNM
PAULUNM's Avatar
That hose looks exactly like one on the turbos- there's an updated 997 part number for an improved version... Assuming it's the same part on the GT3
Old 11-11-2011, 06:25 AM
Number54
Number54's Avatar
Sure "hoses fail eventually", but aren't the issues on the 6GT3 beyond reasonable? Or does everyone believe their hose failure was expected, given they had thrashed the car so much?
Anyone know how often the hoses rip vs the fittings popping out? Because dropping the motor to weld the fittings is expensive, and apparently not a complete solution.
How often should one replace the coolant hoses? Can they all be done without dropping the motor?
Can anyone who's had their fittings welded comment about the Torque Solution fittings for GT1 engines? Worth it? Link: http://www.torquesolution.com/product-p/ts-por-001.htm
Also, anyone have a link where can I order all the coolant hoses?
Thanks.
Quick Reply: Speaking of Coolant lines - a hose blew
