996 GT2/GT3 Forum 1999-2005
Wheel studs
Old 12-04-2012, 10:00 AM
  #31
SH || NC
SH || NC's Avatar
Originally Posted by rodneyr
...just another component to monitor and can break from user error or part failure. I have seem many cars over the years sidelined because one broke ....
That's pretty much every part on the car except the paint....especially for what is essentially a de-tuned race car that is almost 10 years old. Look after the entire car, moreso if you drive it on a track.
Old 12-04-2012, 10:41 AM
  #32
Burger
Burger's Avatar
I keep checking in on this thread as it bothers me to think we should expect studs to fail when properly used. Anyone preaching that sh*t has been drinking large quantities of the kool-aid.
Everything on a racecar is a wear part, we get it. Such as wheels, they shouldn't be raced on for more than 3 seasons and should be checked frequently. But if they cracked within the first season under general, no off/hit, use... I wouldn't be using that brand of wheel without some serious research and support from the manufacturer to resolve the issue. I sure as hell wouldn't be buying more and saying it's fine and you just need to replace them every year for DE use.
Old 12-04-2012, 02:05 PM
  #33
Vonschmidt
Vonschmidt's Avatar
This is the MSI website who we use
http://www.msiracingproducts.com/
Old 12-05-2012, 02:17 PM
  #34
ChrisFL
ChrisFL's Avatar
Thanks, so these look like you need to insert them from behind the hub. Is this much harder than the screw-in type with loctite? Also, can anyone compare this to the apex pro version? thanks
Old 12-05-2012, 02:25 PM
  #35
Ken89911T
Ken89911T's Avatar
Chris,
If you look a little further down the product page, you will see "double ended" wheelstuds. These are what we would typically use. I'm going to look into it, no prices on webpage.
Old 12-05-2012, 04:16 PM
  #36
ChrisFL
ChrisFL's Avatar
Originally Posted by Ken89911T
Chris,
Thanks Ken, didn't see that....
Its hard to see what material they are made from and what process they use to make it also... I'm trying to find someone that possibly makes forged ones... search continues..
Old 12-05-2012, 04:38 PM
  #37
Vonschmidt
Vonschmidt's Avatar
Machined from aircraft quality alloy steel
•Undergo strict quality control procedures
•Finished with a baked-on HM-30 coating containing Teflon & Moly
•Twenty-four stock lengths available
Find your size and ask them the price on that one.
Old 12-05-2012, 05:58 PM
  #38
Burger
Burger's Avatar
http://www.vorshlag.com/product_info...roducts_id=472
Old 12-06-2012, 12:53 AM
  #39
Turn3 Autosport
Former Vendor
Turn3 Autosport's Avatar
We have had good luck with Apex ones and the Rennline ones (which may be made by apex?), But will certainly give the MSI ones a try next time.
Cheers
Quick Reply: Wheel studs
