996 GT2/GT3 Forum 1999-2005
Rotor wear
Old 01-07-2013, 12:16 PM
Ken89911T
Ken89911T's Avatar
Default Rotor wear
Most of us around here know when it's time to swap rotors based on cracking, etc., but what about overall wear/thinning of the rotor? Does anybody know of a recommended thickness minimum, beyond which heat dissipation becomes a problem? I ask because my rears are worn down a fair amount, but don't really have any cracking issues, wondering when the thinness itself is an indication to replace.
Old 01-07-2013, 12:30 PM
gvtesse
gvtesse's Avatar
Iirc minimum thickness for stock rears is 26mm
Old 01-07-2013, 02:23 PM
bobsan
bobsan's Avatar
well Porsche say 2mm total wear from new and you should change, but i've often let them go a lot further than that, I wait until there's a fairly deep wall around the rim say 4mm total..
Old 01-08-2013, 12:50 AM
PointBy
PointBy's Avatar
While you can run discs below the minimum recommended thickness, especially on the street, keep in mind you have lost a lot of the mass from the discs. The discs are a heat sink and as they lose mass they lose the capacity to store and release heat.
Where you will see this first is on the track with overheated pads and fluid and then cracking.
Quick Reply: Rotor wear
