996 GT2/GT3 Forum 1999-2005
Differential fluid
Old 02-04-2013, 02:19 PM
willk47
willk47's Avatar
Default Differential fluid
Hello could someone recommend a good heavy duty differential fluid for track use. I have an 04' gt3 with a new ring and pinion. It is in the northwest so ambient temperature is not mich of an issue. Thanks!
Old 02-04-2013, 03:01 PM
LVDell
LVDell's Avatar
Have you not searched? We seem to discuss this almost weekly.
With that said.....There are 2 main transaxle fluids we use here.....Porsche OEM stuff for street use and Delvac for track or mix use. Changing more frequently is more important than anything.
Old 02-04-2013, 04:03 PM
BuckeyeDrew
BuckeyeDrew's Avatar
You might want to read this thread titled:
OEM Fluids vs. Non-OEM Fluids
*sorry do not know how to link it. It is on the 996 GT3 forum and is near the top at the moment.
Old 02-04-2013, 04:18 PM
bobsan
bobsan's Avatar
https://rennlist.com/forums/996-gt2-...em-fluids.html
Old 02-04-2013, 04:36 PM
BuckeyeDrew
Old 02-05-2013, 01:40 AM
willk47
willk47's Avatar
Thanks as well!
Old 02-05-2013, 09:24 AM
TomGT3
TomGT3's Avatar
No one using LN Engineering? It was recommended by my mechanic when I first purchased the car.
http://www.lnengineering.com/millersoils.html
Old 02-05-2013, 09:50 AM
32krazy!
32krazy!'s Avatar
how much is needed for the trans and diff? i want to do this while i have the car on the lift
Old 02-05-2013, 10:45 AM
runet
runet's Avatar
Appr. 3,3liters.
Old 02-06-2013, 10:35 PM
willk47
willk47's Avatar
I've been trying to locate the delvac fluid in Washington state but have been unsuccessful so far. Does anybody happen to know a vendor in Washington or the west coast? Thanks.
Old 02-06-2013, 10:52 PM
PAULUNM
PAULUNM's Avatar
Your local truck stop should have it- try a T/A truck stop with a service center.
I found it in 1 quart bottles. just make sure you get Delvac 1, not the dino Delvac version.
Old 02-07-2013, 12:55 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,483 Likes on 2,269 Posts
+1
i use extra virgin olive oil but i change every track day. tranny always shifted well.
Old 02-07-2013, 10:45 AM
runet
runet's Avatar
Originally Posted by mooty
+1
This also makes a slipping clutch smell quite nice........
Old 02-07-2013, 01:15 PM
LVDell
LVDell's Avatar
And when you change the gearbox oil, you can make a nice bruscetta
Quick Reply: Differential fluid
