996 GT2/GT3 Forum 1999-2005
Coolant Line Failures- NHTSA
Old 06-18-2014, 03:00 PM
  #241
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
As someone who has seen a coolant line go south and the carnage and complete writeoff it can cause....get it fixed correctly. Ugly.
Old 06-27-2014, 07:08 PM
  #242
F1CrazyDriver
F1CrazyDriver's Avatar
Should i even bother reporting mine blowing with NHTSA ? They have already turned their face away.
Old 06-27-2014, 08:52 PM
  #243
Gofishracing
Gofishracing's Avatar
I would. If every failure is logged Stephen from NHTSA will still see it - I think he looks even though official investigation is concluded. He was top shelf for Government employee. Genuine
Old 07-06-2014, 08:38 PM
  #244
Marv
Marv's Avatar
Originally Posted by almsdriver
After reading the above posts, it looks like Porsche won't fix the potential coolant loss on my 997.1 07 GT3. My engine is out, and I'm thinking to replace the two Tube Necks and/or purchasing them from SharkWerks. I'm in the process of researching exactly what parts need to be re-epoxied to prevent coolant loss, anyone has a link handy? I'm still unsure if the lines/tubes need to be replaced or epoxy to be re-applied? This is what Suncoast quoted me:
997-106-313-72 TUBE NECK 2
Special order 2-3 days
996-106-139-71 WATER SOCKET 1
Special order 3-4 days
996-106-140-71 WATER SOCKET 1
Thanks in advance folks
P.S. I just realized my comment might belong in a different post?
Epoxy is just resetting the ticking time bomb.
Old 07-07-2014, 07:30 AM
  #245
996tnz
996tnz's Avatar
My 2002 996 Turbo has blown 3 coolant fittings now, all in the last 3 years and between 50,000 miles and 70,000 miles. The first just cruising on the highway, the second two on tracks (DE and race, about three 5 lap sessions in). Certainly loosened up the handling on track both times, even for following cars. The NHTSA conclusion was a joke IMHO as they seem to have allowed Porsche to have them limit the investigation to just 18 months or so of 997 builds and the NHTSA went as far as to ignore coolant leak driven loss of control accidents that fell outside that date window. Can't report mine though as I'm not in the States. All 8 fittings are getting tested, then re-epoxied, pinned, plus the collars scuffed and liquid metaled right now.
Old 11-18-2014, 10:05 PM
  #246
adam_
adam_'s Avatar
Lost a fitting.
Had all welded.
Reporting to NHTSA.
Not track use.
Report every one you can.....
Old 11-19-2014, 02:53 PM
  #247
Gofishracing
report it anyway. ya never know. They all will fail. FIX THOSE FITTINGS-ALL OF THEM
Old 11-22-2014, 07:36 PM
  #248
32krazy!
32krazy!'s Avatar
never lost a fitting but had mine welded while the engine was out. was able to pull 2 fittings out with a pair of pliers. was only a matter of time
Old 12-30-2014, 12:16 PM
  #249
roundel
roundel's Avatar
I just logged my failure with the NHTSA.
Old 01-14-2015, 05:32 PM
  #250
Harras71
Harras71's Avatar
Default Coolant fix Porsche 996-997 Turbo & GT3
Hi
I am a Porsche 997.1 GT3 owner from Sweden and I have recently read
a lot about thoose issues about the coolant hoses problem (bad epoxi).
All suggestions is about pinning or welding.
Have any of You guys tried soldering/brazing technique ?
Old 01-14-2015, 07:50 PM
  #251
DKP 97 C2 Coupe
DKP 97 C2 Coupe's Avatar
Harras71, Please read through this thread and you will see that the only way to ensure that your car won't have a coolant fitting failure is to have a competent shop remove the engine and weld the tubes into the coolant manifold. You will be doing yourself and everyone else who you happen to be sharing the road or track with a big favor....
Old 01-14-2015, 09:18 PM
  #252
FFaust
FFaust's Avatar
Originally Posted by Harras71
Hi
Interesting idea, might be worth a look.
Old 02-18-2015, 11:48 PM
  #253
Blitz128
Blitz128's Avatar
Do the 996 Cup engines have the same fitting issues ? I mention this issue to Cup owners I know or met and they are not aware of what this is all about....
Old 02-20-2015, 04:49 PM
  #254
Burger
Burger's Avatar
I've seen threads where the cup engines do have the issue. I've also seen pictures of screw in fittings for the RSR cars. Kind of a mixed bag.
Old 02-20-2015, 05:14 PM
  #255
Gofishracing
yes- there are some similar issues I was told by Dawe Motorsports & Heinlein
Quick Reply: Coolant Line Failures- NHTSA
